I have build a circuit that functions as a variable load. It consists of 4 resistors in parallel - let's call them R1,R2,R3,R4 - each with an activation switch (implemeted with a transistor). R1 has the lowest value, the other resistors have value: Rn = R1*2n-1. I'm currently trying to find an algorithm that calculates the nearest resistance that is above a desired value, Rdes. Does anybody have an idea of how this could be implemented, without looping through all the possible values?
  • \$\begingroup\$ Okay, i found an even better, very simple, solution. Just take the LSB (highest R value = \$R_4 = R_1\cdot{}2^3\$) and divide the desired resistance, \$R_{des}\$ and use the floor function: \$floor(\frac{LSB}{R_{des}}\$) and you have the desired bit pattern that should be switched on. \$\endgroup\$
    – SupAl
    Jul 4 '17 at 11:27
  • \$\begingroup\$ Can you explain a bit further? (1) If the resistors are in parallel you'll get an inverse decay curve. If they're in series you will get a linear rising resistance with your binary pattern. Are you sure you want parallel? (2) The floor() function can't return any values less than 1 so that rules out any combination involving the '1' resistor. \$\endgroup\$
    – Transistor
    Jul 4 '17 at 12:50
  • \$\begingroup\$ (1) part of the reason for choosing parallel, is to be able to handle a larger load. Each (power) resistor takes part of the current (in series they'd all have to take the full current). Furthermore, in my case, linearity is not so important. \$\endgroup\$
    – SupAl
    Jul 5 '17 at 13:47
  • \$\begingroup\$ (2) you should note that with the solution suggested in my comment, the resistance will always guarantee a resistance \$\geq\$ the desired resistance. Also, note that what floor function returns in this case is the bit pattern of the activated resistor values. So if i want the highest resistance, i.e., the value of the LSB, i would plug in \$R_{des}=R_{LSB}\$ and get \$floor(\frac{R_{LSB}}{R_{LSB}})=1\$, that is, in the case of 4 resistors, the value of \$R_4\$. Does that it make sense? \$\endgroup\$
    – SupAl
    Jul 5 '17 at 13:47
  • \$\begingroup\$ I should add, that what i meant by LSB in my first comment is \$R_{LSB}\$ \$\endgroup\$
    – SupAl
    Jul 5 '17 at 13:51
It's called successive approximation and is used quite effectively in determining the digital value of an analogue signal. So, with 4 resistors you would make 4 decisions in order to decide which of the 15 values above zero was most appropriate: -
To make this work like an ADC, feed the unknown resistor with a constant current and do the same for the controllable resistance. Then feed both signals to a comparator that "makes the decision".
Alternatively, buy a cheap ADC and throw away your transistor and resistor network in favour of a much more stable R-2R network and inbuilt algorithm.
  • \$\begingroup\$ This is a nice solution. Actually i wanted to implement it in a uController, but this idea translates well. Thanks! Btw, the reason for not using a DAC is that the transistors/resistors are chosen to be able to handle quite large powers, which is not something ADCs are capable of, to the best of my knowledge. \$\endgroup\$
    – SupAl
    Jul 4 '17 at 9:37
