I would like to know if there is a regulation that would require me to get my product certified because it uses to much power or uses a too high voltage.
My product uses an external adaptor AC-DC that transforms the standard AC (230V) into DC. I want to avoid to use an internal power adaptor because of the certification issue i would face. This adaptor is CE certified.
If my product voltage usage is less than 30V and the power is about 100W. I could in a different configuration go above 30V but always less than 50V.
Is there a voltage or power limit that inforce me to get my product certified?
Thank you
  • \$\begingroup\$ You should be OK with the low voltage directive but laws on electromagnetic compatibility might trip you up. \$\endgroup\$ – Andy aka Jul 4 '17 at 14:00
    \$\begingroup\$ You should get the standard document you want to comply and read it. This is the only to to know for sure what is required. \$\endgroup\$ – Eugene Sh. Jul 4 '17 at 14:03
    \$\begingroup\$ If your market requires certification, then it requires certification regardless. That certification might be easier (lower cost) if you use a certified AC-DC adapter. But you'll still have to be certified for issues like fire safety and EMC. \$\endgroup\$ – The Photon Jul 4 '17 at 14:20
  • \$\begingroup\$ @Andyaka thank you, yes I m aware of the EMC I had some troublesome experience in the past. I'm more worried about the power of this product as i have plenty of space to shield it well. \$\endgroup\$ – dzada Jul 19 '17 at 14:34
  • \$\begingroup\$ @ThePhoton the market does not require anything I believe just the standard EMC for consumers. About the adaptor I hope I can, this is what I would want to do because I don't want any integrated power supply, I 've been down that path in the past and it is a rather painful one ;). However, because of the several different tensions and the power required I'm wondering if I will be limited by a regulation on maximum power with adaptor or maximum current. \$\endgroup\$ – dzada Jul 19 '17 at 14:37
When it comes to CE marking it all depends on which directives your product falls under.
The Low Voltage Directive 2014/35/EU applies to all products which operate between 50 - 1000 VAC and 75 - 1500 VDC.
In your case, as your device is only operating from 30V you shouldn't have to conform to the LVD.
The EMC Directive 2014/30/EU applies to pretty much all electronic devices today and therefore you will have to make sure your device complies.
"The Directive applies to products liable to generate electromagnetic disturbance, or the performance of which is liable to be affected by such disturbance, and to fixed installations."
The RoHS Directive 2011/65/EU affects all electrical and electronic devices and is to limit the hazardous materials used in manufacture as to prevent environmental hazards upon disposal. As long as all your components are RoHS compliant and the PCB manufacturer makes the boards to RoHS compliance then you should be fine. Just remember to get RoHS certificates for every device and process and to keep them stored in case you need them.
The WEEE Directive 2012/19/EU is not strictly a CE directive, and I'm not sure of the legal implications but I'd recommend looking into it as it concerns how your customers can safely dispose of your device and minimise damage to the environment.
I've just listed the directives which I usually deal with and is true for most electronic devices, however you can find all the CE directives here. Depending on what your device is some more may apply to you. Only once you have gone through the appropriate directives and have sufficient evidence can you then CE mark your product.
| improve this answer | |
    \$\begingroup\$ And if it's a toy, then it will need certifying even if it uses no power at all. \$\endgroup\$ – Simon B Jul 4 '17 at 16:23
  • \$\begingroup\$ @SimonB not a toy, but thank you. \$\endgroup\$ – dzada Jul 19 '17 at 14:37
  • \$\begingroup\$ @Doodle So from your point of view only the LVD one applies? and this one only limits in maximum voltage, without limitation of power? (thank you for the links) \$\endgroup\$ – dzada Jul 19 '17 at 14:39
  • \$\begingroup\$ @dzada LVD will apply to you and you're correct there is no power limitations. However, the EMC directive still applies to you and if you get caught you can get a fine up to $2.2 million \$\endgroup\$ – Doodle Jul 19 '17 at 15:37
  • \$\begingroup\$ Also if you plan to sell into the EU then your device must be RoHS compliant, as of next week, it will be illegal to sell a device into the EU that is not RoHS compliant and the same is true for the WEEE directive. Here is a list of the penalties and fines for breaking RoHS and WEEE \$\endgroup\$ – Doodle Jul 19 '17 at 15:40
