This question already has an answer here:
I'm trying to understand some Op-Amp circuits given in a PDF by NI that shows a collection of useful opamp based circuit configurations.
I'm confused about this one that says Inverting amplifier with high input impedance. My doubt is what is the purpose of using a capacitor in the feedback loop of this circuit? Doesn't this circuit behave like an integrator with the capacitor in that position? How is it contributing to high input impedance? Please help!
marked as duplicate by Tom Carpenter, PlasmaHH, JRE, Olin Lathrop, Enric Blanco Jul 7 '17 at 13:19
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
    \$\begingroup\$ Essentially it is down to stability. \$\endgroup\$ – Tom Carpenter Jul 7 '17 at 7:48
  • \$\begingroup\$ It is there to compensate for the parasitic pole formed at the inverting input by the effective capacitance of the pin. \$\endgroup\$ – Peter Smith Jul 7 '17 at 8:36
  • \$\begingroup\$ It's to reduce noise at the output due to the high impedance of the input resistor. Read the flipping data sheet LOL. \$\endgroup\$ – Andy aka Jul 7 '17 at 13:16
No. The capacitor is in parallel to a resistor so the circuit behaves like a PT1-Element - a certain type of low-pass filter.
If you removed R2 the circuit would behave like an integrator.
Opamps are not ideal. They may have problems with high frequencies. The circuit might become instable and produce high-frequency oscillations although no input signal is present.
A circuit shown in your schematic will amplify low frequencies but suppress high frequencies (which might cause problems if they were not suppressed).
Not at all.
However maybe circuits with lower input impedance have less problems with oscillations so no capacitor is needed in that case.
