I am using some integrated schematic/footprint libraries that I downloaded from the internet in a PCB project I am working on. In these libraries, they put 3d component bodies on mechanical layer #1, while all my other libraries have 3d bodies on mechanical layer #13. Is there an easy way to take everything in the library that is on mechanical layer #1 and move it to mechanical layer #13 without having to edit each individual footprint?
1 Answer
Three approaches here: we can move every 3D body to Mech 12, or we can move all the Mech 1 objects to Mech 12, or we can move just Mech 1 3D bodies to Mech 12.
Moving all 3D Bodies to Mech 12
- Right click on a 3D body in one of the components -> Choose "Find Similar Objects"
- "Object Kind" should be "3D Body" with the filter set to "Same." Everything else should be "Any."
- Check the "Whole Library" tickbox in the bottom of the Find Similar Objects pane.
- The PCBLib inspector will pop open, and all the 3D bodies in your library will be selected. Under the "Object Specific" heading there is a field called "Layer." Open the drop drown next to it and select "Mechanical 12."
- You'll get a warning about changing multiple objects and that the action cannot be undone. Click "Yes," and you're finished.
Moving Everything From Mech 1 to Mech 12
- Right click on any Mechanical 1 object in one of the components -> Choose "Find Similar Objects"
- Change the filter on "Object Kind" to "Any" and the filter on "Layer" to "Same." Everything else should still be "Any."
- Perform steps 4 and 5 from the first procedure.
Moving Only 3D Bodies From Mech 1 to Mech 12
- Right click on a 3D body currently on Mechanical 1 in one of the components -> Choose "Find Similar Objects"
- The "Object Kind" field should be "3D Body." Set the "Object Kind" filter to "Same" and the filter on "Layer" to "Same." Everything else should still be "Any."
\$\begingroup\$ You're doing this in the layout editor or the footprint editor? \$\endgroup\$ Jul 7, 2017 at 18:51
\$\begingroup\$ @ThePhoton PCBLib editor. Works for me on Altium 17.1 at least. \$\endgroup\$ Jul 7, 2017 at 19:13
