This is a basic differential amplifier.
I want to modify it in order to have high input impedance (a few \$M\Omega\$ from DC to at least \$200~kHz\$)
I thought about replacing the CE pair input with a CC-CC cascade pair, or a Darlington pair, but I don't think they have good frequency response.
Any suggestion?
I don't really care about the gain, because I will use another stage for that purpose.
  • \$\begingroup\$ What ideas do you have to increase the input impedance? Are you permitted to consider JFETs? \$\endgroup\$ – jonk Jul 8 '17 at 1:47
  • \$\begingroup\$ Real spec? Z of 0.8 pF @ 200 kHz is 1MegOhm \$\endgroup\$ – sstobbe Jul 8 '17 at 1:56
a few ways:
1) reduce Ic;
2) increase current gain;
3) use positive feedback;
5) use fets;
You'll need to boot-strap the C_gate_drain of JFETs, to reach that Zin. Hence the drain of the diffpair cannot be attached to any gain-node.
