Got inrested in DIY fluxes by reply here.
- Can you substitute rosin-core wire with DIY flux and non-rosin-core-wire?
- How and where to actually use DIY fluxes if you have rosin-core wire?
- Which % of ethanol and rosin should be used with SMD components?
- Why to use a soldering flux? ( relates part 2)
- With which substance you can avoid fungi? (relates to part 3)
