Below is an excerpt from an introductory level book about poles and zeros: enter image description here
The transfer function of the RC circuit system above for the output voltage is:
H(s) = s/(s+10)
The book claims that this system's response to e^-10t will be infinite because at s=-10 |H(s)| goes infinity.
So to check this out first I found the Laplace transform of an input e^-10t as:
X(s) = 1/(s+10)
So the output Y(s) must be
Y(s) = X(s) * H(s) = s / (s+10)^2
And for the time domain I take the inverse Laplace transform of Y(s) and plot it in MATLAB as follows:
syms Y s t
warning off;
H = s ./ (s+10); %Transfer function for the RC circuit system
X=1./(s+10); %Laplace transform for the input e^-10t
Y=X.*H; %output
out = ilaplace(Y);
ezplot(out,[0,0.2])
xlabel('t [sec]')
ylabel('Vc [V]')
grid on;
Above plots are the response of this system to e^-10t for 0,2 and 2 seconds interval. According to these above plots the response starts from 1 and then damps to zero.
What is infinite here? I underlined the claim of the book in yellow above. I don't see anything absurd or infinite in the response of this system for the e^-10t input. Where am I wrong here?
You are just producing plots that show the real world and not the underlying maths that lies behind the s-plane. Basically you are thinking in terms of time equivalence of bode plots when you should be thinking in terms of poles and zeros. Hopefully this picture of a 2nd order low pass filter will help: -
The three pictures along the top show the bode plots of three low pass filters where damping is getting less from left to right.
The bottom left picture shows a 3D view of the bode plot aAND the pole zero plot. The bottom right is just the traditional pole zero digram (as would be seen from above on the 3D plot).
  • \$\begingroup\$ What you pointed is what s-plane is about and how it reduces to bode plots on omega axis ect. But it is not what I'm asking. The book claims the actual response for the input e^-10t will be infinite. But it is not infinite according to plots in time domain. Or is it? What is infinite? Can we name it? \$\endgroup\$
    – user16307
    Jul 9, 2017 at 13:29
  • \$\begingroup\$ You are quite correct about the physical response not being infinite. \$\endgroup\$
    Jul 9, 2017 at 15:13
  • \$\begingroup\$ It is a strange statement indeed. Your Matlab analysis is correct and the voltage will dip to -135 mV at 200 ms which makes sense considering the differentiation function. I do not understand either the reference to infinity in the time domain with this \$RC\$ network. You can have a very high output voltage from a \$LC\$ network excited at \$\omega_0\$ if the insertion loss is small (poles are almost pure imaginary) and that is what I use to physically explain the manifestation of a pole. From what book or article did you extract this text? \$\endgroup\$ Jul 10, 2017 at 7:28
  • \$\begingroup\$ Here you can see the pdf of the book: scribd.com/doc/38628560/… I'm trying to understand what is the meaning of pole here for the circuit response in my question relation with the actual output. In other words "response of this system to e^-10t" should be unique and different comparing to any other inputs. What makes the response of input e^-10t different than any other responses in real world time domain? To that I still could not find an answer.. \$\endgroup\$
    – user16307
    Jul 10, 2017 at 9:53
  • \$\begingroup\$ Some kind of qualitative meaning: "When the input to this circuit is e^-10t then we obtain the most.... response in real world(observing the output with an ideal scope ect)".. \$\endgroup\$
    – user16307
    Jul 10, 2017 at 9:55
