I would like to connect multiple TSSP4038 sensors together in such a way that I only have one output (let's call it Y_out), if any of the sensors output is HIGH then Y_out is also HIGH (regardless if some of the other TSSP4038 sensors are low).
According to the datasheet, the TSSP4038 output pin supplies a current of 5mA and a voltage of -0.3 to 5.5 (depending on Vs).
I am thinking the best way to do this is to connect a diode to the output of each sensor (so they don't drain into one another), then connect the nodes after the diodes together to a Pull-Down resistor. If any of the outputs is HIGH then then a voltage across the resistor will be detected.
Would this work? Any suggestions on a better way to do this?
