I'm calculating the width and spacing for my differential signals to meet impedance requirements.
I have downloaded Saturn Impedance Calculator for making calculations.
My PCB stackup has embedded layers that I want to use for differential signals, looks like the next table:
GND Layer 35um
Core 180um
Layer 35um
Prepeg 176um
Layer 35um
Core 180um
PWR layer 35um
So I have two layers there to place differential signals. Now I'm questioning how should I calculate the impedances. I'm unsure if the reference plane would be the GND and the PWR layers.
As an example, If I want to meet the 80Ω diff/ 40Ω single impedances, taking the first inner signal layer, and using the Saturn Edge Coupled asymmetric calculator, the input would be:
H2= 180um
H1= 176um
w = 0.225m
s = 2mm
But I'm unsure if the Height I entered is right, or if I should put the distance to the next reference plane, that is the PWR layer... That distance would be much bigger: 176um + 35um, and would change the impedance.
Anyone know how should I proceed?
