The output of the transformer (A) is a waveform that rises up to some peak positive value and down to some peak negative value relative to 0 volts. Let's say it rises to +100 volts and drops to -100 volts (200 volts peak to peak). Typically, the frequency would be 1 kHz to hundreds of kHz and this means that the capacitor closest to the transformer will pass this peak-to-peak voltage virtually without attenuation.
However, passing this AC voltage without loss doesn't mean that it will still be + and - 100 volts at point (B) - the capacitor blocks DC so point (B) could be raised or lowered by some DC amount with the same AC content superimposed.
However, at point (B) the negative excursions are trapped and restricted (by the diode) to being no more negative than -0.7 volts. This means that the voltage at point (B) now only moves between -0.7 volts and +199.3 volts i.e. there is still the same peak-to-peak voltage but virtually the whole range is now positive.
This is the hard bit done because what feeds (C) is a diode peak detector and at (C) is smoothing capacitor thus, you will get a DC peak voltage of about 199.3 volts minus another 0.7 volts making it 198.6 volts. If you take current from (C) there will be a ripple voltage superimposed on the DC output just like any conventional half wave power supply rectifier circuit.
