I want to ask about the difference between the following when I was reading through a datasheet:
Input high current (pull-up) - Min: /; Max: 20uA
Input high current (pull-down) - Min: /; Max: 500uA
Input low current (pull-down) - Min: -20uA; Max: /
Input low current (pull-up) - Min: -500uA; Max:/
Can someone tell explain the difference between all fours above?.
If the target input high voltage is between 1.7-3.2V, and the voltage source is 3.3V, do I calculate the pull-up resistor value base on the Input high current (pull-up)?
  • \$\begingroup\$ Which datasheet is that from? \$\endgroup\$
    – eeintech
    Feb 11 '20 at 12:07
The datasheets shows that if you use input high current (Pull-up) you can get a max current of 20uA and min of -20uA and the same for the three others I hope that wil help
  • \$\begingroup\$ In that case, if I have a 3.3V supply, do I calculate like this: 1.7V < 3.3V - 20uA * R(Pull-up) < 3.2V \$\endgroup\$
    – Allen W
    Jul 11 '17 at 20:02
