I am trying to power a 12VDC (~3 amps) microprocessor module from a 480 VAC grid power. Can I use a 480 VAC to 24VDC (https://www.automationdirect.com/adc/Shopping/Catalog/Power_Products_(Electrical)/DC_Power_Supplies/24VDC,_3-Phase_Input/PSB24-060S-3)
and 24 VDC to 12 VDC (http://www.ebay.com/itm/SUPERNIGHT-24Vdc-to-12Vdc-5A-Converter-Step-Down-Regulator-Module-60W-/400611133627)
for proper functioning?
closed as off-topic by Brian Carlton, Nick Alexeev Jul 11 '17 at 20:10
This question appears to be off-topic. The users who voted to close gave this specific reason:
If this question can be reworded to fit the rules in the help center, please edit the question.
P=UI law gives 3*12=36W under 12V.
Now you need to account for efficiency loss of your 24V - 12V converter which is 90% efficient (10% loss), the power consumption on the 24V will be 40W.
The PSB24-060S-3 module is capable of 60W which is plenty enough for your application.
The answer is YES, it will work; but...
As much as the 24V power supply seems robust, I don't think the 12V is worth trusting when I read that...
If the ambient temperature exceeds 45 ℃ , please reduce the power output,Or enhance heat dissipation
Your call
