Anyone know what series of connector this is?
Have tried to look at TE/AMP, Molex, Amphenol etc, but no luck. Pitch about 1.5mm, but could be 1.25mm, 1.27mm or 0.05" (didn't have a calliper at hand).
On these boards the connector is SMT, no TH pins at all.
    \$\begingroup\$ Typical JST type connector. Have you look at their catalog? \$\endgroup\$
    – Passerby
    Commented Jul 11, 2017 at 21:44
  • \$\begingroup\$ If you found the answer to your question, you are encouraged to post it with as much detail as possible (es. part number) \$\endgroup\$
    – clabacchio
    Commented Jul 12, 2017 at 10:31
  • \$\begingroup\$ Did you have a different name @clab? \$\endgroup\$
    – Passerby
    Commented Jul 12, 2017 at 21:28
  • \$\begingroup\$ @Passerby no, always been the same \$\endgroup\$
    – clabacchio
    Commented Jul 13, 2017 at 9:48
OP has identified it as the JST brand ZH series connector, after a small reminder.
It is a JST ZH-series connector.
  • \$\begingroup\$ Could you accept this answer (even though it's an answer to your own question)? This way, the StackExchange system will not nag us that we have an open question. Formality. \$\endgroup\$ Commented Jul 13, 2017 at 17:58
