While trying to interface BMP180 to my STM32L4 Controller using libraries I found that the ,
BMP180_RETURN_FUNCTION_TYPE bmp180_get_calib_param(void)
funciton called from
BMP180_RETURN_FUNCTION_TYPE bmp180_init(struct bmp180_t *bmp180)
is unable to access the structure member through the pointer.
The BMP180_RETURN_FUNCTION_TYPE bmp180_init(struct bmp180_t *bmp180) takes the structure address and assign it to a pointer,static struct bmp180_t *p_bmp180; declared globally in bmp180.c. For Example : p_bmp180->calib_param.ac1 =(something) is not actually making any change to the structure member, whereas it changes in the init function( BMP180_RETURN_FUNCTION_TYPE bmp180_init(struct bmp180_t *bmp180)), where the address of the structure is received from bmp180_support.c.
What could be a reason for this and how to solve it? The IDE used is KeilMDK-V5.
The syntax is just wrong.
  • \$\begingroup\$ Hi,static struct bmp180_t *p_bmp180; is the global declaration of the pointer . p_bmp180 = bmp180Add; This is how the pointer is assigned \$\endgroup\$ – Arun Joe Cheriyan Jul 12 '17 at 18:51
This happened because the the optimization level in the project options in the Keil-MDK was set to level 3, when I lowered it to level 1 ,everything worked fine; there was nothing wrong with the code.
    \$\begingroup\$ If the code is correct then the optimization level should modify the behavior of the code.. So your code must be broken in some subtle way.. \$\endgroup\$ – m.Alin Jul 14 '17 at 12:51
  • \$\begingroup\$ Agreed, either undefined behaviour in the code, or a bug in the compiler. \$\endgroup\$ – pipe Jul 14 '17 at 13:13
