I'll start by explaining my circuit:
First of all I'm using a Raspberry Pi and the MCP3008 chip on a breadboard. I have 3.3 V going to my thermistor (\$1 k\Omega\$ at \$0^{\circ}C\$) when it returns I have a \$1 k\Omega\$ resistor that goes to ground, and a wire that goes to the MCP3008 chip.
I'm reading the resistance kind of fine using the chip by using this formula:
$$R = \left(\frac{1023}{reading}-1\right) \cdot R_{0^{\circ}C}$$
e.g.
$$R = \left(\frac{1023}{510}-1\right) \cdot 1000 = 1009.82~\Omega~~at~0^{\circ}C~(ice~water)$$
I've been reading about Steinhart and Hart last night, but I simply can't get a formula that works for converting this into a temperature. I even have a spreadsheet showing values of resistance for different temperatures of the thermistor: Pt-1000 Resistance Scheme
I would really appreciate if someone could show me how this conversion is done, and also if I can get a more precise reading, that would be amazing.
  • \$\begingroup\$ Do you know what a potential divider is? Do you know the analogue range of your ADC? Do you know what ratiometric measurements are? If not, do some background research and re-evaluate your question. \$\endgroup\$
    Jul 13, 2017 at 8:47
I am just suggesting you to try this, consider the below circuit
For example if you read 1.57 volts
from this you can calculate the resistance of the thermistor,
VR2(voltage at resistor R2) = 3.3 * R2/(R1+R2)
in this expression VR2 and R2 is know so you can compute the value of R1.
R1 = ( (3.3 * R2) - (VR2 * R2 ) ) / VR2
for this example the R1 = 1101 OHMS
From this value you can find the temperature by creating a look up table as in the datasheet you included in the link.
  • \$\begingroup\$ Just a sidenote: In some cases input impedance of ADC pin needs to be taken into account. It would be parallel to R2. \$\endgroup\$
    – AndrejaKo
    Jul 13, 2017 at 11:53
    \$\begingroup\$ @karthik: You might be interested to learn about MathJAX for your formulas. See electronics.meta.stackexchange.com/questions/5565/…. \$\endgroup\$
    – Transistor
    Jul 13, 2017 at 11:59
