As shown in the picture above, I want to calculate the voltage drop due to a distributed load.
l is the length of the distributor;
n is simply no of segments, n=l/Δx;
I have written down the sum to determine the voltage drop. But what actually I want to do is to find the "LIMIT OF SUM" of this integral is Δx → 0.
How can I carry out the solution ?
    \$\begingroup\$ Why you didn't title your question "Distributed load volt drops" beats me. \$\endgroup\$
    Jul 14, 2017 at 15:52
  • \$\begingroup\$ I'm sorry I didn't used that title, because that was not the context of this question. \$\endgroup\$
    – spaul
    Jul 14, 2017 at 16:06
I can't say that I feel I completely understood your question. But if I gather it correctly, the value of \$i\$ doesn't change as you move from a finite number of taps to an infinite number of them. This, as you will see, creates a problem that won't be resolvable with a finite answer.
I'm going to label each tap, left to right, as \$k\$ starting with \$k=1\$ on the left and \$k=n\$ at the rightmost tap. You have \$n\$ taps. The current removed at each tap is a constant \$i\$. I'm going to call the entire length, \$L\$ (and not \$l\$.) But the length of each segment of \$L\$ I'll call \$l_k=\frac{L}{n}\$. Length \$L\$ exhibits a certain resistance per unit length \$r\$. The resistance of any segment length is \$r_k=r\cdot l_k=r\frac{L}{n}\$.
The current entering from the left must be the sum of all the branch currents, or \$I=n\cdot i\$. This current must pass through the first segment \$l_1\$ of length \$L\$ and drop a voltage \$v_1=n\cdot i\cdot r\cdot\frac{L}{n}\$. The next segment will drop a voltage \$v_2=\left(n-1\right)\cdot i\cdot r\cdot\frac{L}{n}\$. Etc.
So the question you are asking, "what is the voltage drop across length \$L\$ as \$n\to\infty\$," can be written out this way:
$$\begin{align*} \Delta V=V-V^{'}&= \lim_{n\to\infty} \sum_{k=1}^n \left(n-k+1\right)\cdot i\cdot r\cdot \frac{L}{n}\\\\ &=i\cdot r\cdot L\:\lim_{n\to\infty} \frac{1}{n}\sum_{k=1}^n \left(n-k+1\right)\\\\ &=i\cdot r\cdot L\:\lim_{n\to\infty} \frac{1}{n}\left[\left(n+1\right)\sum_{k=1}^n 1-\sum_{k=1}^n k\right]\\\\ &=i\cdot r\cdot L\:\lim_{n\to\infty} \frac{1}{n}\left[\left(n+1\right)n-\frac{\left(n+1\right)n}{2}\right]\\\\ &=i\cdot r\cdot L\:\lim_{n\to\infty} \left[\frac{1}{n}\frac{\left(n+1\right)n}{2}\right]\\\\ &=i\cdot r\cdot L\:\lim_{n\to\infty} \left[\frac{n+1}{2}\right]\\\\ &=\frac{i\cdot r\cdot L}{2}\:\left[1+\lim_{n\to\infty} n\right] \end{align*}$$
And I don't think I need to tell you how to figure out that limit.
Of course, if you also diminished \$i\$ as a function of \$n\$ then perhaps there might be a different answer. But I didn't see that behavior in your question.
