9
I am trying to design a noise source using discrete transistors and a Zener diode in the avalanche breakdown region. Therefore, I have several questions relating to the use of the diode...
  • How does the quiescent current effect the noise density?
  • How much will the noise density vary with time and temperature at a given quiescent current? This will likely determine whether I need to incorporate AGC into my design.
  • What configuration will maximize the avalanche noise produced by the Zener?
  • Would using a current mirror in place of a resistor to bias the Zener increase or decrease the noise density?
  • Would a voltage or a transconductance amplifier be more effective at amplifying avalanche noise?
If someone has a good noise model for a Zener diode operating in reverse bias, many of these questions can likely be answered. However, I haven't been able to find one, and I don't have the equipment perform the necessary measurements myself.
I currently intend to use a 1N4742 12V Zener in my design.
  • \$\begingroup\$ Did you search the internet and skim through the host of pages about noise generator circuits? Like e.g. maximintegrated.com/en/app-notes/index.mvp/id/3469 \$\endgroup\$
    – JimmyB
    Jul 18, 2017 at 22:01
    \$\begingroup\$ Many sources mention that the noise characteristics depend heavily on the make/model of diode. And because the data is rarely spec'd by the manufacturer designers may have to experiment. \$\endgroup\$
    – JimmyB
    Jul 18, 2017 at 22:05
  • \$\begingroup\$ @JimmyB I've looked at the Maxim article (plus a few others). However, none of the articles I've seen provide only a noise amplifier circuit design idea with minimal analysis and no detail related to the diode. \$\endgroup\$ Jul 23, 2017 at 7:12
+50
First of all, here is a noise diode model for a PN junction from sourceforge It consists of the capacitance of the diode \$ c_d \$, the conduction (or resistance \$g_d = \frac{1}{r_d} \$) and a noise current source \$i_d\$.
The resistance is a standard thermal noise source:
\$S_{r_d} = 4 k T r_d\$
k is the Boltsmann constant
T is absolute temperature
and \$ r_d\$ is the resistance of the device
The current noise source has shot noise and flicker noise:
\$S_{i_d} = 2qI_d\Delta f + \frac{\alpha_H I_d}{f^{\gamma}N}\$
The first term is for shot noise, it is dependent on the electron charge \$q\$ which is equal to \$1.60217662 × 10^{-19}\$ coulombs and \$ I_d \$ is equal the current through the diode.
The second term is for flicker (1/f) noise, and I'll gloss over the details becasue these parameters are unlikely to be found in a datasheet but is more complicated as \$\alpha_H\$ is dependent on semiconductor junction and has a value from \$5 × 10^{-6} \$ to \$ 2 × 10^{-3}\$ and \$\gamma\$ and \$\alpha\$ are material constants, but you would have to model these from experimental data for that device. However if you are using the device with AC coupling (and ignoring DC) you wouldn't have to worry about the low frequency 1/f noise.
The noise source \$S_{i_d}\$ is also correleated, which I will not go into detail here either but the sourceforge link has the math there
An ideal diode (pn- or schottky-diode) generates shot noise. Both types of current (field and diffusion) contribute independently to it. That is, even though the two currents flow in different directions ("minus" in dc current equation), they have to be added in the noise equation (current is proportional to noise power spectral density). Taking into account the dynamic conductance \$ g_d\$ in parallel to the noise current source, the noise wave correlation matrix writes as follows.
(The sourceforge link has an explanation of this but so does Fundamentals of Industrial Electronics 11.2.2 (shot noise) and 11.2.4 (flicker noise) Here is another link for the Fundamentals of Industrial Electronics)
Source: PN Junction diode sourceforge
If you want to see what noise looks like, here is a great figure from EDN. This is from a 12V zener and the noise has been gained up by a factor of 10. Notice that they cut the frequency of the graph off at 1Hz, if we were to see lower than this, 1/f noise would start to dominate. There is also a high frequency cuttoff above 100kHz that is not seen from the capacitance of the circuit.
Figure 2 The power spectral density of the noise output is very flat from 1Hz to 100kHz. As a comparison, the noise of an LM317 regulator is also plotted, as this regulator is normally thought of as being very noisy.
Now on to your questions.
and
The quiescent current affects both shot noise and flicker noise through value \$I_d\$ although it would probably be easier to sum up the total currents through the device into \$I_d\$ and then model the shot and flicker noise.
The problem is modeling a zener diode will require you to measure noise parameters as they are not measured by manufacturers (even noise curves are not provided on most datasheets). Since you have to take measurements, the easiest thing to do is to build the circuit with all these ideas in hand and measure the noise at the end of the day.
At minimum, you could model the shot and thermal noise, and from 1 or 10Hz to the \$c_d\$ cutoff the noise should be white.
Operating it in the avalanche mode or in the reverse diode voltage part of the curve will maximize the avalanche noise. However, a large change in current \$I_d\$ will only produce a small change in voltage because it is operating on the steepest part of the curve.
Source: Zener Diode Tutorial
I would say that it would increase the current noise density. Because a resistor is typically enough to regulate the voltage using a resitor is typically how the current is supplied to the zener, after all, adding a current mirror will add 1/f noise that a resistor doesn't have so it would probably not benefit to add a current mirror vs a resistor.
A zener\resistor combination is typically the source for most voltage regulators. The trick is to keep the current into the resistor (and measuring the voltage with an op amp) as constant as possible.
A voltage amplifier is the way it is commonly done. Transconducance amplifiers have less availability, and have lower impedance, and more noise (from what I've seen in available IC's) all of which are undesirable characteristics.
  • \$\begingroup\$ Thank you. I've been looking for the answer to this question for quite a while. Unfortunately, I don't have the necessary equipment to measure signals in the frequency domain, so that may have to wait until I'm in school. \$\endgroup\$ Aug 7, 2017 at 21:23
  • \$\begingroup\$ You may be able to get 'in the ballpark' by measuring just shot and thermal noise, if your not interested in the 0 to 10Hz region you can neglect the 1/f noise. So run some hand calcs, start your design, and you can fine tune it later. \$\endgroup\$
    – Voltage Spike
    Aug 7, 2017 at 21:27
  • \$\begingroup\$ The reason I asked about the amplifier type is that transimpedance amps are commonly used to amplify photodiode signals. \$\endgroup\$ Aug 8, 2017 at 2:12
