I have a simple arduino driven charger for solar energy to pass into 12V lead-acid battery. However, to use the stored energy I need an analog circuit to cut off discharge at 11.5V. I think a voltage divider ( or 10V zener ) to a N-MOSFET (IRF630), or via a small signal N-MOSFET (2N7000) to a P-MOSFET (IRF9630), plus some extra bits, may be sufficient to switch a relay. I would prefer ditching the relay but then I'd need to heavily heatsink the MOSFET.
My main concern with the relay method is that the relay itself pulls about 0.33W when normal-closed (to clarify, this is also when I discharge the battery), which is a waste. Is there a best practice for cutting off 12V batteries? I have found many on google, of course, but most are 'instructable' type methods, others are rather bulky.
    \$\begingroup\$ A firmly on FET won't need a heatsink for reasonable currents. Make a latching circuit from a P power FET and an N signal FET. Consumes no current off, very little when on, easy to switch between states. Power the voltage comparator from the load side of the FET. \$\endgroup\$ – Neil_UK Jul 17 '17 at 11:59
  • \$\begingroup\$ @Neil_UK That sounds great. I'll look into it. \$\endgroup\$ – user2497 Jul 17 '17 at 12:05
  • \$\begingroup\$ @Neil_UK Can I get by reliably with a voltage divider in this application? \$\endgroup\$ – user2497 Jul 18 '17 at 16:53
    \$\begingroup\$ a voltage divider would be part of the solution \$\endgroup\$ – Neil_UK Jul 18 '17 at 17:32
    \$\begingroup\$ sigh! see my answer. \$\endgroup\$ – Neil_UK Jul 19 '17 at 5:53
M1/IC1 form the latching power switch. It draws no power when off, and little when on.
The TLV431 (not the right symbol, this was close) is designed as a 3 terminal shunt regulator, that maintains the sense voltage at 1.24v. You could think of it as a high gain NPN transistor, with a 1.24v base threshhold voltage.
Consider what happens at the switch point. The sense voltage is around 1.24v, the supply current is passing through 200uA so there's 6v on its supply. This is within its normal operating conditions. Any tiny change in output voltage in either direction will result in switching off, or staying well latched.
I've tested the performance of the TLV431 open loop, and it's well behaved. The cathode stays above 1v, even when ref is well above 1.24v, and it comes out of 'saturation' with no hysteresis. With a cathode resistor of 33k, and 12v supply, it goes from full on to full off in about 4mV of ref terminal movement.
Note that the TLV431 is an unusual device in that the same part number from different suppliers has different specifications. The Texas device only works to 6v, so cannot be used here. The On Semi, Diodes Inc and Zetex devices are specified to 16v, so should be OK. There may be other manufacturers I have not named.
I've shown the components I use to toggle the circuit on and off. Note that for toggling off, the load voltage has to collapse far enough while C1 is holding the FET off. It has only the time constant C1.R5 to do this. If the load has a large reservoir capacitor and a low load, the time constant may need to be increased further.
| improve this answer | |
    \$\begingroup\$ No, you can use any part you like, that will fit with your rails and budget. You mentioned 339 in a comment above. That's a quad, the 393 is its dual equivalent, which will use less power, but with those resistor values, the odd mA probably won't fuss you. You could increase the values of the resistors, those are only suggestions, though keep the ratios (mostly). Now normally, we'd advise against using an op-amp in a comparator position. Here, why not? As soon as it begins to chatter at the threshhold, the supply will turn off, job done! Even the rightly hated 741 would work here! \$\endgroup\$ – Neil_UK Jul 19 '17 at 7:44
    \$\begingroup\$ @user2497 I've added a bit to my answer. Note the caveats about the supplier of the part, and the fact I haven't tested it yet. \$\endgroup\$ – Neil_UK Jul 19 '17 at 11:00
    \$\begingroup\$ @user2497 I've had a further thought about the second circuit. I've still not built one (you're getting real-time thinking here), but I've worked out what the minimum addition should be such that it regulates properly all the time, so I'm much happier that it should work as expected. In case you wonder why I'm spending this effort, I need exactly this circuit for my own purposes, so it's nice to use your question to kick me into designing it! \$\endgroup\$ – Neil_UK Jul 19 '17 at 15:39
    \$\begingroup\$ @user2497 IRF9530 is the default PFET that comes up in the schematic editor, use any type with suitable specs. That part # is max 0.3ohm RDS so you can do a lot better. Don't understand 'before or after', R4 is a potentiometer, to allow you to alter the trip voltage with a knob. If you don't want a knob, remove R4, and adjust the values of R2/3/99 to set the trip point. The comparator is available in leaded or leadless, take your pick. \$\endgroup\$ – Neil_UK Jul 20 '17 at 5:25
    \$\begingroup\$ @user2497 Tested the 431, works fine without the 99 components, updated the post. It's easy enough to modify R2/3/4 to reduce the range of adjustment, or for different cells. \$\endgroup\$ – Neil_UK Jul 21 '17 at 20:24
