I think I'm doing my Boolean algebra wrong on this circuit. Could someone check my work here? enter image description here
Your calculations are not correct as far as I can see, it's hard to follow where you have go the first equation.
You should follow a process as such:
  1. Start by labelling all nodes. There are 6 output nodes by my count, including the output Q.
  2. Write down the each equation of each node in relation to the nodes before it. You will end up with 6 equations in this case.
  3. Substitute in prior equations to build up a final non-simplified equation for Q.
  4. Simplify using Boolean algebra rules.
I'll give you a hint, in this particular example you will end up with a very simple equation that is well grounded.
| improve this answer | |
  • \$\begingroup\$ "well grounded" - bit of a huge clue there! \$\endgroup\$ – Glen Yates Jul 17 '17 at 23:11
