I built a stick welder using two microwave transformers and a DC bridge rectifier. To control the heat, I created a triac current regulator attached to the AC input of the transformers. I have used this specific circuit for a long time with these transformers however I got an overheat blow out of my BTA41-600B triac last time (the triac physically caught fire). I ordered 4 new ones, and they seem to be instantly failing with the load terminals stuck open. If I allow full current to pass through the triac, it doesnt break, however when I try to regulate the current, it instantly stops regulation and stays shorted. Is there something wrong with my design? And if so, why are these the only triacs being affected?
  • 5
    \$\begingroup\$ Counterfeit parts are common. Make sure you are purchasing from a reputable distributor. \$\endgroup\$ – rdtsc Jul 18 '17 at 1:03
  • \$\begingroup\$ Can you provide a link to the source? \$\endgroup\$ – Russell McMahon Jul 18 '17 at 11:01
  • \$\begingroup\$ ebay.com/itm/4pcs-STMicroelectronics-BTA41-600B-Triac-600V-40A/… \$\endgroup\$ – jakerz Jul 19 '17 at 20:57
  • \$\begingroup\$ It doesn't seem that the seller is aware of any issues and offered a return. \$\endgroup\$ – jakerz Jul 19 '17 at 20:58
  • 4
    \$\begingroup\$ I would not have believed it if I had not seen it with my own eyes, but the following listing item title actually appears on a usual suspects ecommerce site: "BTA41-600B [absolutely original ic] fake a compensable special store diy electronic ic component" \$\endgroup\$ – Chris Stratton Jul 21 '17 at 19:06
These were most likely counterfeit, I ordered a new batch directly from the company and they worked perfectly.
