I'm using Adafruit's Huzzah ESP8266 breakout board (overview & pinouts), and I'd like to take input from a Radioshack piezo on the analog input pin without frying it. (Piezo datasheet, for reference.)
I've found a few people with a similar setup using an Arduino, and it seems like at a minimum I'd need something like a zener diode and 1MΩ resistor, like in the basic circuit from this PDF (page 12). The analog pin on the Huzzah has a 1V max voltage, so my sense is that I've got to make some adjustments to divide down the voltage further, and maybe include a capacitor? Super new to EE, so any advice on including & calculating the proper values for components is appreciated.
The end goal is to take input from the piezo and use it to set hue + brightness of an RGB LED, similar to the Adafruit LED ampli-tie project, but obviously with just a single LED. I can provide more details on that if it's relevant to getting up and running with the piezo input.
  • \$\begingroup\$ Be careful to distinguish between a piezo buzzer (which makes a continuous noise as long as you apply power to it) and a piezo sensor or element, which it the bare piezo element - it will make a "click" when you apply and remove DC power. The buzzer won't work as a sensor. \$\endgroup\$ – Peter Bennett Sep 1 '19 at 23:33
The 1MOhms resistor will "load" the piezo element and reducing the level of the induced voltage during normal usage. However, a sudden force applied to the element may cause a voltage spike which would kill the analog input, so you should add a series resistor of a few hundred ohms between the analog input and the piezo element.
Edit: the PDF you linked uses a Zener diode to clip the voltage, however the value it chose is a 5V Zener which is for Arduino analog inputs. You should choose a Zener with around a 1.2V breakdown voltage.
