Hi,
I'm having a problem with the USART_RX_vect interrupt of the ATMega 328p. The receiving works fine and I'm able to evaluate the sent bits (so it's not due to the baudrate) but everytime I send a bit, the ISR gets executed 4 times.
So a ISR like this:
ISR(USART_RX_vect) {
uart_transmit('t');
uart_flush();
Will transmit {'t', 't', 't', 't'}
I have no clue why this is happening, and I hope you can help me.
My main
is a empty loop (of course I execute uart_setup
). My ISR is like above. I'm using avr-gcc on linux.
This is my UART Setup:
void uart_setup() {
UBRR0H = (BAUDRATE >> 8);
UBRR0L = BAUDRATE;
// Set 8-Bit mode
setBit(UCSR0C, UCSZ01);
setBit(UCSR0C, UCSZ00);
setBit(UCSR0B, RXEN0); // Receiver enable
setBit(UCSR0B, TXEN0); // Transmitter enable
setBit(UCSR0B, RXCIE0); // Enable RX Interrupt
sei(); // Enable global interrupts
void uart_transmit(unsigned char data)
while (!( UCSR0A & (1<<UDRE0))); // wait while register is free
UDR0 = data; // load data in the register
void uart_flush( void ) {
unsigned char dummy;
while ( UCSR0A & (1<<RXC0) ) dummy = UDR0;
