Here is my question regarding SNR of a SIMO model (one transmitter antenna and K receiver antennas):
$$\vec{y}_{K\times 1}=\vec{h}_{K\times 1}x+\vec{n}_{K\times 1} $$
In a Matlab simulation, if say, I want to simulate the system performance under SNR=10 dB and noise is (0,\$\sigma^2\$), the general process would be: assign a power, say 1, to \$x\$, then use given SNR=10dB to assign corresponding value to \$\sigma\$.
The code of \$\vec{n}\$ should be: Noise=sigma*randn(K,1).
Here is my confusion: when we say SNR=10dB, does it mean:
1) On each receiving antenna, \$SNR= h^2_i/\sigma^2 =10dB\$?
2) Or, totally for all receiving antennas, \$SNR= ||\vec{h}||^2/\sigma^2 =10dB\$?
3) Or, since every antenna has a copy of noise, \$SNR= ||\vec{h}||^2/(K\sigma^2) =10dB\$ ?
So which understanding is correct? If none of them is right, could someone explain to me about the correct way to do the simulation?
Each antenna/LNA pair has noise independent of the other antenna/LNA pairs.
You have to define what the SNR means: output of a combiner is 10dB SNR, or input to each LNA is 10dB.
