I am currently trying to use the LM317 with a stable output voltage of 1,25 V. The general formula is $$ Vo = Vref\cdot\left(1+\frac{R2}{R1}\right) + Iadj\cdot R2 $$ The formula is according to this schematic
I used this circuit to create the 1,25 V output voltage:
This circuit is directly according to the formula. R1 is infinitely high, R2 is zero. In general I measure the 1,25 V output voltage. But when the load is drawing current, everything gets unstable. Then I measure voltages higher and lower than 1,25 V...
I read some things regarding the minimum current in Adj Terminal. Therefore I thought about calculating R1 to create Iadj at ~50µA (according to ST LM317 datasheet). But whats with R2, should it be shortened to ground in this case?
I also thought about inserting a series resistor at the output, just to create a small load of ~1mA. Maybe the LM317 needs a minimum load... Are there any suggestions? Thanks for your help.
  • \$\begingroup\$ What load are you applying? Does it vary, is it constant? How unstable is it, do you have a waveform? What kind of output cap do you use (i.e. what ESR does it have) \$\endgroup\$ – PlasmaHH Jul 21 '17 at 8:41
  • \$\begingroup\$ At the load are various resistors creating a load current between 0,5µA to 50 mA. Relays are used to switch between the load resistors. \$\endgroup\$ – Merki Jul 21 '17 at 8:46
  • \$\begingroup\$ Output caps are normla electrolyt 10µ capacitors, ESR is neglectable.. \$\endgroup\$ – Merki Jul 21 '17 at 8:47
Yes, as suggested, the LM317 DOES need a minimum load. The specification sheet suggests about 10 mA, LM317 see table 7.5 "minimum load current".
The bias current to run the internal error amplifier comes from the input pin (#3 of the TO220 package) and the circuit is completed by output current at the output pin (#2), while the sense pin (#1) carries only a small trickle of sense current. If the R1 resistor is 120 ohms, it will be an adequate load resistance (R2 = zero ohms). Lacking an adequate load, though, the formula is inapplicable, because the internal amplifiers are lacking the needed power supply current.
Indeed it does. It is specified in the datasheet for the exact version you are using, and is typically between 2-10 mA.
In fact, this is (one of?) the reasons behind the slightly unusual value for R1 in the example schematics. It creates a minimum load of 5 mA at all times.
Adding a 240 ohm resistor to your circuit should clean it up.
