9
I'm looking at two integrated circuit packages: SOIC and SOP. They seem (almost) identical (pitch, overall size, etc...)
SOP
SOIC
Is there any important differences between these two packages that I am overlooking?
    \$\begingroup\$ SOP is a special successor of SOIC, as 20s of Wikipedia would have told you! \$\endgroup\$ – Marcus Müller Jul 21 '17 at 14:52
    \$\begingroup\$ @MarcusMüller, that doesn't seem to apply. It says SOP are versions of SOIC with pin pitch less than 1.27 mm, while OP's link shows an "SOP" package with 1.27 mm pitch. \$\endgroup\$ – The Photon Jul 21 '17 at 15:31
  • 4
    \$\begingroup\$ Unfortunately, the packaging industry seems to be in a mess, smaller packages come in huge variety of widths and HEIGHTS. Note: it is not just SOP, it is 8-SOP-225, looks like an arbitrary number. Then VSSOP, MSSOP, TSSOP go... there are "package names" and "supplier cases", you never know unless carefully check the datasheet and particular IC suffix. \$\endgroup\$ – Ale..chenski Jul 21 '17 at 17:54
8
Yes, there are subtle differences that may or may not affect a particular design. For example, look at the specified package height from the bottom of the pins to the top of the body.
Whether differences like these are "important" depend on your application. Never trust the manufacturer's package name. You must manually step through all relevant dimensions.
protected by Tom Carpenter May 18 '18 at 9:24
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
