A rectifier I salvaged from a broken oasta machine uses am odd plastic barrel connector. On the rectifier end, it looks like a banana pin housed in a translucent white plastic barrel. On the cable end, it looks like a tube. The diameters of the terminals are smaller than a standard banana connector. Both terminals snap together on two ridges.
What is the name of this connector?
Male connector pins Male donnector body
Female connector mate
Femalw donnector body
  • \$\begingroup\$ Looks like a bullet connector to me. \$\endgroup\$ – Ignacio Vazquez-Abrams Jul 22 '17 at 21:42
  • \$\begingroup\$ Yeah, I thought that, but haven't seen this one. \$\endgroup\$ – user148298 Jul 22 '17 at 21:43
    \$\begingroup\$ A regular bullet connector doesn't fir. This one has a smaller diameter and locks in using the tabs. \$\endgroup\$ – user148298 Jul 22 '17 at 22:06
It's called a custom connector.
common Shell, and Pin Socket Contact for each side.
One of these pins may fit your dimensions when you find the single wire interlock shell
| improve this answer | |
  • \$\begingroup\$ Thanks. I found it. It is made by Molex part # 1625-1PRT. It is hideously expensive $16 for 1 at amazon. I guess I will use standard terminal connectors. Kinda sucks because they are really cool and keeps things tidy. \$\endgroup\$ – user148298 Jul 23 '17 at 5:41
