I am using LIS3MDL 3 axis magnetometer sensor for car detection project. while I am using raw data, I understand that if sensor is exposed to hard-iron effect then this sensor can not read old values.
so how can I eliminate this effect and calibate sensor for stabile working.
thank you for all.
Without having read it deeply, this document seems a good way to do it. Is the first result in google, by the way.
  • \$\begingroup\$ I have already found it, but I want to ask for something easier. \$\endgroup\$ – user136320 Jul 24 '17 at 13:53
  • \$\begingroup\$ I think there is no easy way to do it. Maybe you can adapt the code used in the 9-DOF Razor IMU: github.com/Razor-AHRS/razor-9dof-ahrs \$\endgroup\$ – Raul O. Jul 24 '17 at 15:15
