I'm not too versed in EE so I apologize for my duncitude -
My thought is that you can precisely control a stepper motor, but can you inversely get precise readings out of a stepper motor?
For example: if you have an xy plane controlled by stepper motors, you can say "navigate to 0,0 by moving x motor 40 times and y motor 30 times". If you manually drug both axis in position, could you get a reading of x: 40, y: 30?
    \$\begingroup\$ It is possible theoretically by monitoring the coil voltages but practically one would add an encoder disc for a much simpler circuit and better accuracy. \$\endgroup\$ – Janka Jul 25 '17 at 3:33
While turning a stepper motor does generate an AC output, it's not suitable for a general position sensor.
The magnitude of signal it generates is proportional to its speed. As long as the table moves at least at at a minimum speed (which will depend on the sensitivity of your measurement hardware), then you will see all the pulses. Move at a lower speed, and you will miss pulses. With a simple voltage measurement, you would not be able to tell whether the motor was stationary, or turning very slowly.
A position sensor really needs the ability to be able to tell stationary from slow. An optical encoder can do this, as can a synchro.
Some constructions of stepper may permit you to sense its position by measuring the inductance of all the windings, treating it as a sort of variable reluctance synchro. However, by the time you've done that, it would be far simpler to use an optical encoder.
  • \$\begingroup\$ Awesome, thank you! :) \$\endgroup\$ – jmchargue Jul 25 '17 at 16:30
