I recently bought this solenoid valve for an Arduino project where I need to flow liquid between 50 and 100 degrees Celsius.
I didn't find a circuit example or a technical sheet specific to this component. Based on a circuit I found for a different solenoid valve, I know I need a transistor and a rectifier diode in order to make it work but I'm not sure if I can use the very same components : A TIP120 Darlington Transistor and a 1N4001 Diode ( from this circuit example ).
Thanks for any help
