I found the method for c language.But I do not know how to perform this in VHDL. Let a fixed point number (12 downto -19) like 3456.478396 I need break this number entirely into separate numbers 3456.478396 --> 3, 4, 5, 6, (dot) , 4, 7, 8, 3, 9, 6... into 11 integer type variables. How to perform this in VHDL?
signal example : sfixed(4 downto -4);
--'example' contains 9.75 then it is storage as "01001.1100".
--simply example ="10011100".
--10011100 --> integer 156
How to get back original 9.75 number from 156 to separate into single digits?
I USED,
library ieee;
library ieee_proposed;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee_proposed.float_pkg.ALL;
use ieee_proposed.fixed_pkg.ALL;
use ieee_proposed.fixed_float_types.ALL;
  • \$\begingroup\$ How is the original number represented? How do you want it to be represented once "broken"? \$\endgroup\$
    – Eugene Sh.
    Commented Jul 25, 2017 at 16:07
    \$\begingroup\$ depends how the number is held. If in BCD, then it's easy. If it's in binary, then you have to convert to decimal first. \$\endgroup\$
    – Neil_UK
  • \$\begingroup\$ @Eugene Sh in the question I have mentioned that I need break this number entirely into separate numbers 3456.478396 --> 3, 4, 5, 6, (dot) , 4, 7, 8, 3, 9, 6... into 11 integer type variables. \$\endgroup\$
    – oppo
    Commented Jul 25, 2017 at 16:38
  • \$\begingroup\$ See here: stackoverflow.com/questions/23871792/… Once your binary integer is converted to BCD, each digit is separate... \$\endgroup\$
    – Mishyoshi
    Commented Jul 25, 2017 at 17:06
    \$\begingroup\$ @Mishyoshi That doesn't solve the right hand side of the problem. The decimal values. \$\endgroup\$ Commented Jul 25, 2017 at 17:08
Here's some pseudocode.
Let's take the ones left of the decimal first, max number is \$15_{10}\$ => 2 decimal digits.
signal ex : sfixed(4 downto -4);
temp <= ex(4 downto 0);
L_0 <= temp mod 10;
temp <= temp/10;
L_1 <= temp mod 10;
Example:
ex=\$12_{10}\$=\$1100_{2}\$
temp <= 12
L_0 <= 12 mod 10 = 2
temp <= 12/10    = 1
L_1 <= 1 mod 10  = 1
And then the ones to the right, smallest number => 0.0625 => 4 decimal digits. Same method as before, just multiply by \$625_{10}\$ before you start. Because \$0001_{2}\$ in binary translates to \$.0625_{10}\$ in decimal. So the bit width of temp should be \$ceil(log_2(625×15))=\$ 14 bits because \$15_{10}\$ is \$1111_{2}\$ which is your highest value.
temp <= ex(0 downto -4);
temp <= temp*625
R_3 <= temp mod 10;
temp <= temp/10;
R_2 <= temp mod 10;
temp <= temp/10;
R_1 <= temp mod 10;
temp <= temp/10;
R_0 <= temp mod 10;
Example:
ex=\$0.1875_{10}\$=\$0011_{2}\$
temp <= 3 = 0011
temp <= 3*625 = 11101010011        = 1875
R_3 <= 1875 mod 10                 = 5
temp <= 1875/10                    = 187
R_2 <= 187 mod 10                  = 7
temp <= 187/10                     = 18
R_1 <= 18 mod 10                   = 8
temp <= 18/10                      = 1
R_0 <= 1 mod 10                    = 1
And it should be displayed like this:
\$L_1 L_0 . R_0 R_1 R_2 R_3\$
All the constant division by 10 can be replaced by a multiplication with \$\frac{1}{10}\$. So it's not too inefficient to implement. I'm fairly certain that the modulus operator comes with the standard library.
If you use 6 bits for the right hand side of the decimal point. Then the bit width for temp should be \$ceil(log2(63×15625))\$ = 20 bits. This is probably not the most efficient way, it's a way I came up with just now on my own. It should work without any major problems.
Since this is being done on an FPGA you can parallelize the multiplication, for R3,R2,R1 and R0, multiply their temp with 1, \$\frac{1}{10}\$, \$\frac{1}{100}\$ and \$\frac{1}{1000}\$ so you get the values straight away, instead of serially. And then use the mod 10 on them.
EDIT
Mishyoshi gave me an idea for how this could be solved in another way. \$L_0\$ and \$L_1\$ are solved like before, but the \$R_{0..3}\$ can be done in another more efficient way.
signal temp : sfixed(4 downto -4);
//We need 4 to the left of the decimal point because then we can capture
//all the single digits
temp <= "0000" & ex(0 downto -4);
temp <= temp*10;
R_0 <= temp(3 downto 0); //Copy the 4 MSB bits
temp <= "0000" & temp(-1 downto -4); //Delete the 4 MSB bits
temp <= temp*10;
R_1 <= temp(3 downto 0);
temp <= temp*10;
R_2 <= temp(3 downto 0);
temp <= temp*10;
R_3 <= temp(3 downto 0);
Example:
temp <= "0000" & "0011"                     = 0000.0011 = 3
temp <= 3*10                           = 30 = 0001.1110
R_0 <= "0001.1110"(3 downto 0)              = 0001 = 1
temp <= "0000" & temp(-1 downto -4)         = 0000.1110
temp <= 14*10                         = 140 = 1000.1100
R_1 <= "1000.1100"(3 downto 0)              = 1000 = 8
temp <= "0000" & "1100"                     = 0000.1100
temp <= 12*10                         = 120 = 0111.1000
R_2 <= "0111.1000"(3 downto 0)              = 0111 = 7
temp <= "0000" & "1000"                     = 0000.1000
temp <= 8*10                           = 80 = 0101.0000
R_3 <= "0101.0000"(3 downto 0)              = 0101 = 5
As you can see it's all about getting the bits to the "ones" place, the 4 bits to the left of the decimal point.
That's way fewer bits needed for this. In this other solution you can, like Mishyoshi said, put them in a pipeline.
  • \$\begingroup\$ I do not understand what is, and how is this got smallest number => 0.0625 => 4 decimal digits. the number 625 \$\endgroup\$
    – oppo
    Commented Jul 25, 2017 at 18:52
    \$\begingroup\$ if you put 1/16 in to the calculator, then it will show 0.0625, if you just look at the non-zero-numbers it says 625. That means that a 0000.0001 in binary is 0.0625 in decimal. So the "weight" of the 1 is 1/16. But since we're on the "right hand side", we can just ignore the decimal point and treat it as 0625. In other words, just multiply by 625. Because we're just converting to BCD, we're not doing anything fancy. \$\endgroup\$ Commented Jul 25, 2017 at 18:57
    \$\begingroup\$ If it would be 6 bits then you would multiply by 15625 because the 0000.000001 in binary is 0.015625 in decimal. Remove the decimal and you got 000001 is 015625. So multiply the 1 by 015625 and then start chopping out the digits. \$\endgroup\$ Commented Jul 25, 2017 at 19:03
    \$\begingroup\$ I might be wrong but for a 4 bit fixed point fractionnal value, you can perform a binary multiply of 10000 because it is valued 0.0625 (4digit => 10^4). Then convert that to BCD using link i provided. Value will be 10000 times too large, so consider decimal point 4 position to the left. There would only be a single multiply with readily available multiplier and a bunch of adders which could be pipelined. \$\endgroup\$
    – Mishyoshi
    Commented Jul 26, 2017 at 3:06
  • \$\begingroup\$ Hmm, you're onto something @Mishyoshi. You need to do something more than just multiply by \$10^4\$ though. \$\endgroup\$ Commented Jul 26, 2017 at 3:17
