I'm having a hard time figuring out how to emulate 13.56Mhz RFID Mifare tags using Arduino and basic components i have tested some ideas but i couldn't read bytes due to difference in protocols and frequencies i even opened a new Mifare 1k tag and soldered its coil to the circuit to avoid errors in induction calculation and i have calculated the frequency but im out of luck, i already found many similar projects for 125khz but i have the rc522 RFID reader so i can't test 125khz yet,
and for 125khz i found this:
(www.instructables.com/id/RFID-Emulator-How-to-Clone-RFID-Card-Tag-/)
Also
(www.instructables.com/id/Stupid-Simple-Arduino-LF-RFID-Tag-Spoofer/) This is the code i have used
int coil_pin = 9;
void setup(){
    Serial.begin(9600);
    //Set pin as output
    pinMode(coil_pin, OUTPUT);
   //Start it as low
   digitalWrite(coil_pin, LOW);
//Does manchester encoding for signal and sets pins.
//Needs clock and signal to do encoding
void set_pin_manchester(int clock_half, int signal)
   //manchester encoding is xoring the clock with the signal
   int man_encoded = clock_half ^ signal;
   //if it's 1, set the pin LOW (this will tune the antenna and the reader
    sees this as a high signal)
   //if it's 0, set the pin to HIGH  (this will detune the antenna and the
    reader sees this as a low signal)
 if(man_encoded == 1)
 else
      digitalWrite(coil_pin, HIGH);
      Serial.println(man_encoded);
 void loop()
 //this is the card data we're spoofing.  It's basically 10 hex F's
 int data_to_spoof[64] = {1,1,1,1,1,1,1,1,1, 1,1,1,1,0 ,1,1,1,1,0, 1,1,1,1,0
 ,1,1,1,1,0, 1,1,1,1,0 ,1,1,1,1,0, 1,1,1,1,0 ,1,1,1,1,0, 1,1,1,1,0
 ,1,1,1,1,0, 0,0,0,0,0};
 for(int i = 0; i < 32; i++)
     set_pin_manchester(0, data_to_spoof[i]);
     delayMicroseconds(5);
     set_pin_manchester(1, data_to_spoof[i]);
The schematics enter image description here
Also tried this, with difference in capacitor and inductor values as i'm working with 13.56Mhz
I appreciate any help
  • \$\begingroup\$ "i've tested some idea" is anything but a clear problem statement. \$\endgroup\$ – Dmitry Grigoryev Jul 26 '17 at 14:50
  • \$\begingroup\$ seriously man: i even open a new Mifare 1k tag and solder its coil to the circuit to avoid error in induction \$\endgroup\$ – Ninja Jul 26 '17 at 15:03
  • \$\begingroup\$ it's a lot of trial and errors for the last couple days even me can't remember all what i tested \$\endgroup\$ – Ninja Jul 26 '17 at 15:04
  • \$\begingroup\$ Welcome to EE.SE. Can we encourage you to capitalise and punctuate properly for legibility and credibility. Your Arduino compiler wouldn't let you away with it. \$\endgroup\$ – Transistor Jul 26 '17 at 15:28
  • \$\begingroup\$ sure i will review it \$\endgroup\$ – Ninja Jul 26 '17 at 15:32
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
