I am using pic16f1823 and MPLab as IDE. I want to have simple interrupt on RA2 and turn on LED, when it come. I've wrote This code, but it doesn't work!
#pragma config FOSC = INTOSC    // Oscillator Selection (INTOSC oscillator: I/O function on CLKIN pin)
#pragma config WDTE = OFF       // Watchdog Timer Enable (WDT disabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable (PWRT disabled)
#pragma config MCLRE = ON      // MCLR Pin Function Select (MCLR/VPP pin function is digital input)
#pragma config CP = OFF         // Flash Program Memory Code Protection (Program memory code protection is disabled)
#pragma config CPD = OFF        // Data Memory Code Protection (Data memory code protection is disabled)
#pragma config BOREN = OFF      // Brown-out Reset Enable (Brown-out Reset disabled)
#pragma config CLKOUTEN = OFF   // Clock Out Enable (CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin)
#pragma config IESO = OFF       // Internal/External Switchover (Internal/External Switchover mode is disabled)
#pragma config FCMEN = OFF      // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor is disabled)
// CONFIG2
#pragma config WRT = OFF        // Flash Memory Self-Write Protection (Write protection off)
#pragma config PLLEN = ON       // PLL Enable (4x PLL enabled)
#pragma config STVREN = ON      // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will cause a Reset)
#pragma config BORV = LO        // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), low trip point selected.)
#pragma config LVP = ON         // Low-Voltage Programming Enable (Low-voltage programming enabled)
And for main app, we have :
#include <stdio.h>
#include <stdlib.h>
#include "main_10.h"
void interrupt tc_int(void)
    //if (INTCONbits.INTF == 1)
    if (INTCONbits.T0IF && INTCONbits.T0IE)
        LATCbits.LATC1 = 1;
        __delay_ms(1000);
        LATCbits.LATC1 = 0;
        __delay_ms(1000);
    INTCONbits.INTF = 0;
void main (void)
    OSCCON = 0x76;//Very Important,this will command micro to use internal oscillator
    //prepare Interrupt on A2
    TRISAbits.TRISA2 = 1; //make interrupt port as input.
    OPTION_REGbits.INTEDG = 0; //make sense to falling edge.
    INTCONbits.INTE = 1;    //interrupt enable.
    INTCONbits.GIE = 1; //Globally enable interrupts.
    INTCONbits.INTF = 0;    //make interrupt flag clear.
    //prepare output on PORTC.bit1
    LATCbits.LATC1 = 0; //initialization of portc.0
    TRISCbits.TRISC1 = 0; //make portc.0 as output.
    while(1)
And we have Proteus simulation like this: enter image description here
where is the mistake? Any help would be appreciated!
  • \$\begingroup\$ Is this a complete schematic? MCLR seems to be enabled in your config, yet it is floating. \$\endgroup\$ – glen_geek Jul 27 '17 at 10:34
  • \$\begingroup\$ > where is the mistake? You didn't read the datasheet on how to turn that pin to GPIO. \$\endgroup\$ – dannyf Jul 27 '17 at 10:46
  • \$\begingroup\$ Many thanks @glen_geek, for your comment! Yes! you are right! I changed the schematic; but i think this is not the main problem of lack of interrupt \$\endgroup\$ – paradisal programmer Jul 29 '17 at 9:13
  • \$\begingroup\$ I've read the datasheet @dannyf, and that was just a simple mistake! \$\endgroup\$ – paradisal programmer Jul 29 '17 at 9:16
You are setting A2 as an output using TRISAbits.TRISA2 = 0; should be 1. Easy to remember: a zero looks like an "o" (output) and a 1 looks like an "I" (input).
  • \$\begingroup\$ Many thanks for your answer, i changed TRISAbits.TRISA2 to 1, but interrupt is not working, yet \$\endgroup\$ – paradisal programmer Jul 29 '17 at 8:36
  • \$\begingroup\$ I edited my code, and correct that mistake \$\endgroup\$ – paradisal programmer Jul 29 '17 at 8:43
  • \$\begingroup\$ @paradisalprogrammer To clarify: Do you still have the problem, even after you incorporated these changes? \$\endgroup\$ – pipe Jul 29 '17 at 9:48
  • \$\begingroup\$ Yes! @pipe , when i press push button on PORTA.2, LED on PORTC.2 doesn't blink \$\endgroup\$ – paradisal programmer Jul 29 '17 at 9:59
After alot of effort, I solved my problem. thanks to @JohnBirckhead. we encountered with two wrong bit set.
    1. TRISAbits.TRISA2 = 0
       //should be converted to:
    2. INTCONbits.T0IF && INTCONbits.T0IE
       //should be converted to (in if statement in isr function):
        INTCONbits.INTF == 1 && INTCONbits.INTE == 1
       // because we are working with external interrupt.
