PIC24FJ1024GB610 from Microchip
Debugger Pikit On Board from Explorer 16/32 Development Board from Microchip
I wrote a program, where I tried to create a 250 ms Delay using Timer 1
, and whenever the Timer 1 Interrupt Flag IFS0bits.T1IF
is set, the pin connected to the LED PORTAbits.RA7
/ LATAbits.LATA7
will toggle.
this is the following code:
#include <xc.h>
#pragma config FWDTEN = OFF //watchdog timer off
#pragma config FNOSC = FRC //Osc source from FRC (8MHz)
#pragma config ICS = PGD2
#define LED LATAbits.LATA7
#define TMR1_IF IFS0bits.T1IF
#define GLOBAL_INT INTCON2bits.GIE
#define TRIS_LED TRISAbits.TRISA7
void Set_LED (void)
TRISAbits.TRISA7 = 0;//output
ANSAbits.ANSA7 = 0;//Digital Not Analogue
LED = 0;
void Set_Timer1 (void)
T1CONbits.TCS = 1;//Clock Source internal from Tcy
T1CONbits.TCKPS = 2;//1:64
T1CONbits.TSIDL = 0;//continues through idle mode
Fosc = 8MHz, Fosc/2 = Fcy = 4MHz
Tcy = 1/Fcy = 1/4 us = 0.25 us
t = 250 ms = 250,000 us
t = Tcy*(PRESCALAR)*PR1
PR1 = t/(Tcy*PRESCALAR)
PR1 = 250,000 / (0.25*64)
PR1 = 15625
PR1 = 15625;
T1CONbits.TON = 1;//run timer
int main (void)
Set_LED ();//Set LEDs
Set_Timer1 ();//Set Timers
while(1)
while(!TMR1_IF);//stay till IFS0bits.T1IF = 0
LED = !LED;//Toggle LED / LATAbits.LATA7
TMR1_IF = 0; //Clear Interrupt Flag
return 0;
I run the program into the PIC24, and I expect the LED to blink very fast but instead, it takes (approximately) 40 sec to toggle the LED.
This confuses me, because I checked OSC Datasheet page, and the Timer 1 Datasheet page from the PIC24FJ1024GB610 Datasheet, it seems fine, and I should expect a 250 ms toggle.
Looking at the DS, this is what I deducted:
FNOSC = FRC
hence source is FRC (Fosc = 8MHz)- Fosc gets divided by 2, insctruction frequence (4MHz)
- Register associated with
DOZE
isCLKDIV
CLKDIVbits.DOZEN = 0
, CPU Peripheral Clock ratio is 1:1, hence Fcy = 4MHz- Tcy = 1/Fcy, Tcy = 1/4 us = 0.25 us
T1CONbits.TCS = 1
Clock Source is internal from FRC Oscillator- Clock Source is internal
Tcy
which in our case is 0.25 us - No Gate operation
T1CONbits.TCKPS = 0b10
Prescalar is 1:64, (each 64 Clock Source tick will incrementTMR1
register by 1- if
TMR1 == PR1
,T1IF
will be set.TMR1
counts till it is equal to the value inPR1
giving the information I have to make a 250 ms (250,000 us) time delay, I used to following equation:
- t = Tcy*(PRE)*(PR1)
- 250,000 = 0.25*64*(PR1)
- PR1 = 250,000/(0.25*64)
- PR1 = 15625
I thought that it is straight forward, can someone help me with my question.
Thank you in advance.
