I have a product that will be tested for a dielectric test, which says that the rocker switch placed at the beginning or rather the first component after inlet connector, will be exposed to around 1500 VAC and 1700VDC for approximately 1 minute. Can a rocker switch withstand this voltage? I can't find any electrical specification in datasheets for rocker switch. They have only mentioned mechanical properties like dimensions etc.
What properties should I look for to select this rocker switch for my product?
  • \$\begingroup\$ Why does it have to 'withstand'? If it arcs at overvoltage but doesn't catch fire, is that acceptable? \$\endgroup\$ – Whit3rd Jul 28 '17 at 9:38
  • \$\begingroup\$ what is the meaning of "arcs"? \$\endgroup\$ – skii Jul 28 '17 at 9:42
  • \$\begingroup\$ 'arc' means make a spark. That isn't a normal-input-voltage test, so normal operation cannot be required of your device. What IS required? If the switch makes a spark or a fuse opens, is that acceptable? \$\endgroup\$ – Whit3rd Jul 28 '17 at 9:44
    \$\begingroup\$ The dielectric test is probably designed to test the insulation rating of the switch - not its ability to switch at that voltage. The test probably involves closing the switch applying 1700 V to both L and N terminals on the device (0 V difference between the two pins) and making sure that it doesn't conduct to chassis or a test probe. (I have never seen this done.) \$\endgroup\$ – Transistor Jul 28 '17 at 10:26
  • \$\begingroup\$ @ Transistor that's right!! \$\endgroup\$ – skii Jul 28 '17 at 11:26
Look for a "dielectric rating" on your switches
Your switch datasheets should (especially if they have a NRTL component recognition) publish a "dielectric rating" for the switch. For instance, using the NKK CWSA/CWSB series power rockers as an example, they are rated for up to 3kV from contacts to case for 1 minute. If this rating is greater than your high-pot test, then you are good.
If they don't publish this value, then find a different switch manufacturer that des.
| improve this answer | |
From this link: enter link description here it seems that toggle switches seem to have a maximum voltage. So I guess it will be equal for rocker switches.
There a sort of voltage 'divider' is used, so I guess you can do something similar. Or use a small control signal through the rocker to send to a transistor to switch on the main circuit.
