I am working on an inclinometer project using an accelerometer, a MMA1220KEG and a PIC16F1783. It is designed to switch a relay when the angle of inclination is below 15°, and illuminate a series of LEDs to indicate the user is close to this angle. If at 15° inclination or above for more than 1 second the relay disengages until at a safe angle.
I have made up a prototype on a breadboard with resistors and LEDs to simulate the outputs as per the specification but I have a problem where pin 16 (RC5) is constantly high and the corresponding LED is illuminated. When the power is removed from the PIC the LED switches off but strangely comes back on if a high is applied to pin 3 (RA1).
I have tried numerous things to try and rectify the problem, such as changing bits in the alternative pin function register to change the priority of the output pins, but nothing seems to help. I thought a fresh, knowledgeable perspective would help from the people of this site.
I've checked the accelerometer which works as expected.
Please see schematic, at the moment I'm trying to rectify the code for the indicators.
I've reprogrammed another PIC and changed part of the code relating to the red zone.
    /* Project: PIC16F1783  Measure MMA1220KEG accelerometer                      */
    /*                      output indicator LEDs and activate relay below 15 deg */
    /* Author: Ben Thomas                                                         */
    /* Date: 27/07/17                                                             */
    /* Pin Assignments;     P2  RA0 AN0 input from Accelerometer                  */
    /*                      P3  RA1 input connected to status pin (high if fault  */
    /*                          or if self test is initialised)                   */
    /*                      P4  RA2 output connected to accelerometer self        */
    /*                          test pin (output high to reset delay before       */
    /*                          checking status pin                               */
    /*                      P11 RC0 output connected to GREEN LED (below trip 1   */
    /*                          output high else low Between 0-11 degrees)        */
    /*                      P12 RC1 output connected to AMB1 LED  (between trip 1 */
    /*                          and trip 2 output high else low between 11-12     */
    /*                          degrees)                                          */
    /*                      P13 RC2 output connected to AMB2 LED (between trip 2  */
    /*                          trip 3 output high else low between 12-13 degrees)*/
    /*                      P14 RC3 output connected to AMB3 LED (between trip 3  */
    /*                          and trip 4 output high between 13-14 degrees      */
    /*                          else low)                                         */
    /*                      P15 RC4 output connected to AMB4 LED (between trip 4  */
    /*                          and 5 output high between 14-15 degrees else low) */
    /*                      P16 RC5 output connected to RED LED (equal and above  */
    /*                          trip 5 output high 15 degrees and above else low) */
    /*                      P17 RC6 output connected to accelerometer fault LED   */
    /*                      P18 RC7 output connected to relay triggering device   */
    /*                          output high when accelerometer output is below 15 */
    /*                          degrees if above 15 degrees for 1S or longer      */
    /*                          output low until below 15 degrees                 */
    //Calculate average ADC result and convert to angle
            //angle = asin((int)(ADRES-Voffset) / SENSE);
    /* Files to Include                                                           */
        #include <xc.h>         /* XC8 General Include File */
        #include <stdint.h>
        #include <math.h>
    // CONFIG1
    #pragma config FOSC = INTOSC    // Oscillator Selection (INTOSC oscillator: I/O function on CLKIN pin)
    #pragma config WDTE = OFF       // Watchdog Timer Enable (WDT disabled)
    #pragma config PWRTE = OFF      // Power-up Timer Enable (PWRT disabled)
    #pragma config MCLRE = ON       // MCLR Pin Function Select (MCLR/VPP pin function is MCLR)
    #pragma config CP = OFF         // Flash Program Memory Code Protection (Program memory code protection is disabled)
    #pragma config CPD = OFF        // Data Memory Code Protection (Data memory code protection is disabled)
    #pragma config BOREN = ON       // Brown-out Reset Enable (Brown-out Reset enabled)
    #pragma config CLKOUTEN = OFF   // Clock Out Enable (CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin)
    #pragma config IESO = ON        // Internal/External Switchover (Internal/External Switchover mode is enabled)
    #pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor is enabled)
    // CONFIG2
    #pragma config WRT = OFF        // Flash Memory Self-Write Protection (Write protection off)
    #pragma config PLLEN = ON       // PLL Enable (4x PLL enabled)
    #pragma config STVREN = ON      // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will cause a Reset)
    #pragma config BORV = LO        // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), low trip point selected.)
    #pragma config LVP = OFF         // Low-Voltage Programming Enable (Low-voltage programming disabled)
    /* User Global Variable Declaration                                           */
    //#define NSAMPLES    3         //size of sample array
    //#define _XTAL_FREQ 4000000  //oscillator frequency for delay_ms()
    #define Voffset     2.5         //offset of Accelerometer
    #define SENSE       0.25         //sensitivity of Accelerometer
    #define TRIP1P      2087        //trip 1 positive end of green zone 1st amber zone
    #define TRIP1N      2009        // trip 1 negative end of green zone 1st amber sone
    #define TRIP2P      2091        // Trip 2 positive second amber zone
    #define TRIP2N      2005        //Trip 2 negative second amber zone
    #define TRIP3P      2094        //trip 3 positive third amber zone
    #define TRIP3N      2002        //trip 3 negative third amber zone
    #define TRIP4P      2094        //trip 4 positive fourth amber zone
    #define TRIP4N      1998        //trip 4 negative fourth amber zone
    #define TRIP5P      2101        //trip 5 positive red zone
    #define TRIP5N      1995        //trip 5 negative red zone
    //#define db_cnt1     122         //1S db count for timer0
    #define STATUS      LATAbits.LATA1   //accelerometer status pin
    #define SLFTST      LATAbits.LATA2   //accelerometer self test pin
    #define GREEN       LATCbits.LATC0   //GREEN LED 'OK' zone
    #define AMB1        LATCbits.LATC1   //AMB1 LED 11-12 degrees
    #define AMB2        LATCbits.LATC2   //AMB2 LED 12-13 degrees
    #define AMB3        LATCbits.LATC3   //AMB3 LED 13-14 degrees
    #define AMB4        LATCbits.LATC4   //AMB4 LED 14-15 degrees
    #define RED         LATCbits.LATC5   //RED LED 15 degrees and above
    #define FAULT       LATCbits.LATC6   //LED indicating Accelerometer fault
    #define RLY         LATCbits.LATC7   //Relay trigger output
    uint8_t db_cnt1;
    uint8_t state = 0;
    //uint8_t smp_buf[NSAMPLES];      //Array of samples for moving average
    /****PROTOTYPES****/
    /****MACROS********/
    #define TMR0_2  (TMR0 & 1<<2)   //access to TMR0<2>
    void initialise(void)
        TRISC = 0;          //configure all PORTC as outputs
        //TRISA = 0;          //configure all PORTA as outputs
        TRISA = 0b00000011;     //configure RA0 and RA1 as inputs only
        ANSELAbits.ANSA0 = 1;
        CM1CON0 = 0;        //Disable comparator 1 (RB0, RB1 digital)
        CM2CON0 = 0;        //Disable comparator 2 (RC0, RC1 digital)
        FVRCON = 0;          //Disable CVref -> RC2 usable
        state = 0;
        //configure ADC (P147/148)
        //ADCON0
        ADCON0bits.ADRMD = 0; //ADRESL and ADRESH provide data formatted for a 12-bit result
        ADCON0bits.CHS = 00000; //AN0 selected
        ADCON0bits.GO_nDONE = 0; // conversion not in progress
        ADCON0bits.ADON = 1;    //ADC enable bit
                                //-> AN0 ready for sampling
        //ADCON1
        ADCON1bits.ADFM = 0;    //ADC result format is 'sign-magnitude result format
        ADCON1bits.ADCS = 100;  //ADC Conversion clock = FOSC/4
        ADCON1bits.ADNREF = 0;  //ADC negative voltage reference is Vss
        ADCON1bits.ADPREF = 00; //ADC positive voltage reference is Vdd
        ADCON2bits.TRIGSEL = 0000;  //ADC auto conversion disabled
        ADCON2bits.CHSN = 1111;     //ADC Negative reference - selected by ADNREF
        //configure timer Option Register (174)
        OPTION_REGbits.nWPUEN = 1;  //All weak pull-ups are disabled (except nMCLR if enabled)
        OPTION_REGbits.TMR0CS = 0;  //Timer0 clock source internal instruction cycle Fosc/4 (Fosc = 32MHz/4 = 8MHz)
        OPTION_REGbits.PSA = 0;     //Prescaler is assigned to the Timer0 module
        OPTION_REGbits.PS = 111;    //Prescaler rate select bit 1:256
                                    //-> increment every 32 uS
                                    //-> TMR0 overflows every 8.192mS ()
        APFCONbits.SDOSEL = 1;
        APFCONbits.CCP1SEL = 1;
        APFCONbits.SCKSEL = 1;
        APFCONbits.SDISEL = 1;
        APFCONbits.TXSEL = 1;
        APFCONbits.CCP2SEL = 1;
        T1CON = 0;
        PSMC1CONbits.PSMC1EN = 0;
        PSMC2CONbits.PSMC2EN = 0;
    /*void delay1s(void) //1 second delay
        db_cnt1 = 0;
        while (db_cnt1 < 1000/8) //125*8ms =1s
            TMR0 = 0;
            while (TMR0 < 250) //wait for 8mS 8000/32
            ++db_cnt1;          //increment 8ms counter
        return;
    /* Main Program                                                               */
    void main(void)
        //double     angle;              // Scaled ADC output in degrees (0-99)
        initialise();
        while(1)
            switch(state)
                case 0:
                    ADCON0bits.GO = 1;          //start ADC conversion
                    while (ADCON0bits.GO_nDONE)    //wait until conversion finished
                    state = 1;
                    break;
                case 1:
                    if ((ADRES<TRIP1P && ADRES>TRIP1N) && STATUS == 0)  //green zone below 11 degrees
                        FAULT = 0;
                        state = 10;
                        break;
                    else if (((ADRES>=TRIP1P && ADRES<TRIP2P) || (ADRES<=TRIP1N && ADRES>TRIP2N)) && STATUS == 0) //AMB1 zone between 11-12 degrees
                        FAULT = 0;
                        state = 20;
                        break;
                    else if (((ADRES>=TRIP2P && ADRES<TRIP3P) || (ADRES<=TRIP2N && ADRES>TRIP3N)) && STATUS == 0)    //AMB2 zone between 12-13 degrees
                        FAULT = 0;
                        state = 30;
                        break;
                    else if (((ADRES>=TRIP3P && ADRES<TRIP4P) || (ADRES<=TRIP3N && ADRES>TRIP4N)) && STATUS == 0)    //AMB3 zone between 13-14 degrees
                        FAULT = 0;
                        state = 40;
                        break;
                    else if (((ADRES>=TRIP4P && ADRES<TRIP5P) || (ADRES<=TRIP4N && ADRES>TRIP5N)) && STATUS == 0)    //AMB4 zone between 14-15 degrees
                        FAULT = 0;
                        state = 50;
                        break;
                    else if ((ADRES>=TRIP5P && ADRES<=TRIP5N) && STATUS == 0)                                        //RED zone 15 degrees or higher
                        FAULT = 0;
                        state = 60;
                        break;
                    else if (STATUS == 1)                //FAULT state mode
                        state = 70;
                        break;
                    else state = 0;
                    break;
                case 10:        //green zone angle less than 11 degrees
                    RLY = 1;
                    GREEN = 1;
                    AMB1 = 0;
                    AMB2 = 0;
                    AMB3 = 0;
                    AMB4 = 0;
                    RED = 0;
                    state = 0;
                    break;
                case 20:        //1st amber zone 11-12 degrees
                    RLY = 1;
                    GREEN = 0;
                    AMB1 = 1;
                    AMB2 = 0;
                    AMB3 = 0;
                    AMB4 = 0;
                    RED = 0;
                    state = 0;
                    break;
                case 30:        //2nd amber zone 12-13 degrees
                    RLY = 1;
                    GREEN = 0;
                    AMB1 = 0;
                    AMB2 = 1;
                    AMB3 = 0;
                    AMB4 = 0;
                    RED = 0;
                    state = 0;
                    break;
                case 40:        //3rd amber zone 13-14 degrees
                    RLY = 1;
                    GREEN = 0;
                    AMB1 = 0;
                    AMB2 = 0;
                    AMB3 = 1;
                    AMB4 = 0;
                    RED = 0;
                    state = 0;
                    break;
                case 50:        //4th amber zone 14-15 degrees
                    RLY = 1;
                    GREEN = 0;
                    AMB1 = 0;
                    AMB2 = 0;
                    AMB3 = 0;
                    AMB4 = 1;
                    RED = 0;
                    state = 0;
                    break;
                case 60:        //red zone 15 degrees and above
                    GREEN = 0;
                    AMB1 = 0;
                    AMB2 = 0;
                    AMB3 = 0;
                    AMB4 = 0;
                    RED = 1;
                        state = 61;
                        break;
                    else
                        state = 0;
                        break;
                    break;
                case 61:
                        //delay1s();
                        db_cnt1 = 0;
                        while((((ADRES>=TRIP5P && ADRES<=TRIP5N) && STATUS == 0))&& db_cnt1 <1000/8) //1S debounce delay
                            TMR0 = 0;   //clear timer
                            while (TMR0 < 8000/32)
                            ++db_cnt1;
                        if(db_cnt1 >= 1000/8 && ((ADRES>=TRIP5P && ADRES<=TRIP5N) && STATUS == 0)) //if debounce delay is exceeded disengage relay
                            RLY = 0;
                            state = 0;
                            break;
                        else
                            state = 0;
                        break;
                    else
                        state = 0;
                    break;
                case 70:        //initiate test to decipher if unit is faulty
                    SLFTST = 1;
                    db_cnt1 = 0;
                    while (db_cnt1 < 48/8)  //48ms delay
                        ++db_cnt1;
                    SLFTST = 0;
                    db_cnt1 = 0;
                        ++db_cnt1;
                    if(STATUS == 1)
                        FAULT = 1;
                        state = 0;
                        break;
                    else
                        state = 0;
                        break;
                    break;
Now more LEDs are on, the ones attached to pins 11, 12, 13, 14 and 16.
  • \$\begingroup\$ I don't have time to get deeply into your problem, and the lack of a schematic increases the workload of anyone reading who tries to understand this configuration. However, one quick bit of help: "when the power is removed from the PIC the LED switches off but strangely comes back on if a high is applied to pin 3 (RA1)" - It seems you applied a voltage to RA1 when the MCU was unpowered. Don't apply a voltage to a pin on an unpowered MCU, even if that would be OK when the same MCU is powered. This can cause various problems, too long to explain here. Best of luck with the question. \$\endgroup\$
    – SamGibson
    Jul 28, 2017 at 14:43
  • \$\begingroup\$ Have a look at this video from eevBlog by Dave Jones to understand why LED can come on when you have no power to PIC. youtube.com/watch?v=2yFh7Vv0Paw Agree with SamGibson, please provide a schematic. \$\endgroup\$
    – J Rodgers
    Jul 28, 2017 at 15:00
  • \$\begingroup\$ Please see edit for schematic and additional info, code has been edited and a new PIC was programmed, new results are more LEDs illuminate while PIC is powered. \$\endgroup\$
    – btommo
    Jul 28, 2017 at 15:57
That's just a very poor form of programming. You have two choices:
  1. remember the priority of calculations; or
  2. use brackets liberally so you enforce the order of calculations to your liking.
it is designed to switch a relay when the angle of inclination is below 15 degrees and illuminates a series of LEDs ...
then code like that, instead of a set of states without any comments for you (later) or others trying to help you to understand easily what's going on.
