As I just discovered, when a 3-terminal adjustable voltage regulator (LM317, LD1086) is operating with Vin less than setpoint + dropout, its output is unregulated Vin - dropout. I want it to output nothing, zero volts.
It occurs to me there might be a solution using an external zener and a PNP transistor that turns on when there is a greater than 0.6V difference between Vin and the zener setpoint, but then I would need a separate voltage divider to determine essentially the same setpoint, with two potentiometers in the case of an adjustable power supply.
Any more elegant solutions out there? Perhaps there is a more-than-3-terminal device I should be using instead?
