I have a power distribution board for my Quadcopter. It is powered by a 3s Lipo and the following are connected:
  1. 12 Volt outlet for ESCs: 4 ESCs 12 Amp
  2. 5V Outlet: Connected my 5V Gyroscope and Arduino Nano
  3. 12 V outlet: Connected a receiver using 3.3 V regulator.
I don't have any additional outlets.
Question is, how do I add more devices by pulling voltage from existing outlets by connecting in parallel, as the Volts will be the same. I understand Amps will get divided.
  1. Is it ok, to add more devices in parallel to let us say my 12V outlet, where I connect couple of more 3.3 V regulators to run 3.3 V devices and couple of 5V regulators to run 5V devices.
Based on the specification of LIPO and power dist module below, is there a way I can determine the max devices I can connect to both 5V and 12V outlets on my power distribution module?
here is the spec of my power distribution module: General:
  • Input voltage range (3S-4S LiPo operation): 9 - 18V DC
  • Regulated 5V and 12V outputs
  • 6 ESC outputs & 1 pair VCC/GND pads
ESC outputs:
  • Continuous current: 25A*4 or 15A*6
  • Peak current (10 seconds/minute): 30A*4 or 20A*6
BEC 5V output:
  • Designed for RC Receivers, Flight controllers, OSD, and Servos.
  • DC/DC synchronous buck regulator.
  • Voltage: 5.0 +/- 0.1VDC
  • Continuous current: 2 Amps (Max.2.5A 10s/minute)
  • Output Ripple: 40mV (VIn=16V, VOut=5V@2A load)
  • Short-circuit tolerant (5 seconds/minute)
BEC 12V output:
  • Designed for Video TX or FPV camera with linear regulator.
  • The battery should be 4S LiPo (13~18V DC)
  • Voltage: 12.0 +/- 0.3VDC
  • Continuous current: 500mA (Max.0.8A 5s/minute)
  • Short-circuit tolerant (2 seconds/minute)
BEC 12V @ 3S LiPo
  • Output voltage= 3S LiPo voltage -1V
I posted the question in another forum and got a reply. I can power many devices from the power distribution module.As long as I do not exceed the current.
