I want to use several nRF radios together with an adapter like this:
Also, for the device I'm using these for (two nRF's) also I have other components which I put on a breadboard.
However, the nRF adapter does not have pins so I cannot stick it in a breadboard, but I want to keep it together. I don't like two nRF's dangling when I move the breadboard for example. Also, there does not need to be a connection from the nRFs to the breadboard.
Is there some smart idea how to connect such adapter to a breadboard? Glueing to the breadboard is not an option, since I want to reuse the breadboard. I was thinking about glueing it to IC sockets and stick them in unused holes in the breadboard but those sockets are not meant for breadboard... I can use tape maybe, but probably I'm not the first one having this 'problem' and there are better ideas.
    \$\begingroup\$ I did come across this version of the adapter board. arduino-for-beginners.blogspot.co.uk/p/… \$\endgroup\$ Aug 1, 2017 at 14:12
  • \$\begingroup\$ @JImDearden That is indeed nice, however, cost ($10 shipping cost) make it a bit much for something like that (assuming I have already 5 in possession and bought 5 new ones for about $1,50). Glueing them on a cheap IC would be cheaper, or glueing some plastic between two sets of pin headers and glue the adapter on top of it :-) \$\endgroup\$ Aug 1, 2017 at 14:20
  • \$\begingroup\$ The main reason for using the header board was you need the current at 3v3. Have a look at ebay.co.uk/itm/… as an alternative to using a header board. \$\endgroup\$ Aug 1, 2017 at 14:53
  • \$\begingroup\$ @Jim Dearden True .. and possible some capacitors. But I already have those adapters ... tomorrow when I'm home I'm going to check if I can use an IC with some tape/elastic or glue (DIP8 ICs like 74HC595N cost like 5 cents) \$\endgroup\$ Aug 1, 2017 at 14:56
I put this as answer to maybe bring others with the same 'problem' to this idea (or not).
I think the pictures are speaking for themselves.
Some remarks:
  • I haven't checked if the elastics will bother the PCB antenna
  • It is not 100% stable while inserting wires but after that it stays quite well (depending on the strength/length of the elastics of course)
  • I used 74HC595N ... make sure no metal is pressed (in my case no problem). Otherwise use isolation tape.
  • The 74HC595N only performs as 'base', it does not make any (useful) electronic contact with both the breadboard and the RF (adapter).
Cost for 74HC595N: about 5 cents?
Advantages:
  • 74HC595N are reusable
  • Reasonable stable (after wiring)
Disadvantages:
  • It is cheap ... it looks also cheap
[Picture 1 [Picture 2]
