37
If infrared light is not visible to the human eye, why do most tv remote controls and security cameras appear to have a visible red colored LED lit when the infrared light is being emitted?
Is that visible red light present as a convenience (introduced by grace of the component designer?) or as a by-product of emitting actual infrared light?
Is it possible to have infrared light emitted without this visible red color?
    \$\begingroup\$ Do you see the infrared with your eyes or with a CCD camera? The CCD camera is sensitive for infrared, but usually the color filters will filter it out from all channels. \$\endgroup\$
    – Oskar Skog
    Aug 2, 2017 at 4:24
    \$\begingroup\$ If you see it with your bare eye, then it's a red LED. Looks to be a convenience feature, as I can't see any red light from my remote. (My phone's camera however does see that light.) // It might be possible that it's UV and not IR though. \$\endgroup\$
    – Oskar Skog
    Aug 2, 2017 at 4:33
  • 4
    \$\begingroup\$ Your picture looks like an illustration rather an actual photo, with red stuff added so it looks cool. \$\endgroup\$ Aug 2, 2017 at 16:35
  • 7
    \$\begingroup\$ @OskarSkog LEDs are not lasers. They do not emit a single, pure wavelength. If you see a dim red glow from an infrared emitter, you probably are seeing the visible tail of a power spectrum that contains a much brighter, invisible component. \$\endgroup\$ Aug 2, 2017 at 17:05
    \$\begingroup\$ TV remotes do not typically have a visible LED in the front edge position that is aimed at the TV!!! They have it on the button panel (nowadays often under the translucent, soft buttons themselves), as a feedback that the remote control has battery power (it is working). \$\endgroup\$
    – Kaz
    Aug 3, 2017 at 19:53
10 Answers 10
58
The simple answer is that they are using near IR. LED manufacturers have a good handle on how to make them so they are affordable.
Their center frequencies may be invisible to the M-1 eyeball (i.e. human eye), but unless they put a filter in front of the LEDs (which cause them to produce less illumination) there will be some of it that you can see.
The effect is minor. Basically, to see it you must look directly at the emitter. You're not going to see it in reflections or scene illumination.
Far-IR is completely invisible. But a whole lot more expensive because the manufacturing process is different.
Near-IR emitters are mass-produced. Far-IR not so much.
IR lasers are another story. They emit on a single frequency, so there is no gaussian curve describing their output in the frequency domain. They are so invisible that they can be dangerous. Working around lab CO\${}_2\$ lasers, for instance, requires removal of all jewelry and controlling the beam. They will not trigger a blink response so you can sustain a lot of damage in a short time and not know it right away.
  • 9
    \$\begingroup\$ There's another factor too: most CCDs are more sensitive to near IR than far, so using near IR for illumination is more efficient. \$\endgroup\$
    – Jules
    Aug 2, 2017 at 12:09
  • 20
    \$\begingroup\$ Am I the only person who doesn't know what an M-1 eyeball is? Also, this may be of interest Thorlabs 780nm LED spectrum \$\endgroup\$
    – uhoh
    Aug 2, 2017 at 13:51
  • 33
    \$\begingroup\$ @uhoh: "Mark 1 eyeball". Original equipment, from the factory, no aftermarket modifications, no external additions. \$\endgroup\$ Aug 2, 2017 at 15:23
  • 8
    \$\begingroup\$ Lasers don't emit a single frequency. They emit a very narrow Gaussian distribution. \$\endgroup\$
    – Matt
    Aug 2, 2017 at 16:37
  • 17
    \$\begingroup\$ Even a low wattage IR laser can do interesting things to the eye. When I was much younger, before diode lasers were regulated, I was trying to use a 2 watt communications laser running at an unmeasured number of milliwatts with black and white film (which is more sensitive to IR light than visible) to create a hologram (epic fail). When aligning the laser I didn't realize I had left it powered on. When it swept across my eye I felt nothing, but had a pretty diffraction grating temporarily etched on my cornea that had me seeing rainbows for a week. \$\endgroup\$
    – pojo-guy
    Aug 2, 2017 at 21:23
16
The transition from visible wavelengths to invisible is not infinitely abrupt. Your eye's sensitivity falls off in the IR range. But in the near IR, it may not be zero sensitivity.
And the emission spectrum of LED's is not infinitely narrow. So not all of the photons coming off of an LED have the exact same wavelength.
The net effect of these two things is that when near infrared LED's are driven very hard, some photons will come off of them that are visible. To the camera, those LED's are like a super bright spotlight. But to your eye, they are just glowing modestly.
I have also seen cameras where the LED's were not visible at all. So there is some variation there.
    \$\begingroup\$ I have seen the same with some TV remotes, too. Taken apart you can see they have a plastic filter that helps to block the visible portion. \$\endgroup\$
    – SDsolar
    Aug 2, 2017 at 5:08
    \$\begingroup\$ @SDsolar, Yes, I have seen those filters. They block most visible light but pass IR. \$\endgroup\$
    – user57037
    Aug 2, 2017 at 5:30
10
I have never ever noticed that a remote control or any other IR-LED emits any red light. It might glow very, very dark, because a tiny little bit of the light is emitted at higher, visible wavelengths.
Maybe, you are a bit special and can see light deeper into the IR range, that would be interesting.
On the other side, you ask
which basically means
Why are there two LEDs, one red, ond IR?
That's just a feedback that the device is working. Remote controls have a visible LED on the top (mine is blue, by the way) and an IR LED pointing forward.
Security cameras indicate that they are on / are recording to the ones in front of the camera, there are even fake cameras with no more electronics than just this LED and its blinking circuit
And on advertisements like your picture, the IR LEDs are often "photoshoped" red.
In reality, camera sensors can see IR light, but it appears blueish white. This is the reason why for example cigarettes sometimes glow blue instead of red on photos. Today, there is a filter in front of the camera sensor, which prevents this. It typically does not block the IR of an LED which is very near to the visible spectrum, but some filters do.
    \$\begingroup\$ Whether or not that image was photoshopped I cannot confirm. However I can tell you that's exactly what they (many that I have seen) look like in the dark when the infrared is emitting. Are my eyes special in this regard? Well, that could be another question entirely - perhaps for the "Biology" Stack Exchange site. \$\endgroup\$
    – dtmland
    Aug 2, 2017 at 5:20
  • \$\begingroup\$ If you remove the IR filter you can see the light from many remotes. I have worked extensively with the product called TAG. It is not a remote, but you can definitely see the IR LED in TAG with your eye. It is very, very faint, but you can see it. The peak current in the LED is around 2A, but it is pulsed at relatively low duty cycle. In a dark room, with no filter, the light is somewhat visible, and it is definitely an IR LED. It is also true that many products with IR LED's use a filter to block the visible light from the LED. TAG did this. \$\endgroup\$
    – user57037
    Aug 2, 2017 at 5:29
    \$\begingroup\$ "is emitted at higher, visible wavelengths." - You mean "higher frequencies" or "lower wavelengths" :) \$\endgroup\$
    – JimmyB
    Aug 2, 2017 at 12:30
    \$\begingroup\$ Low power IR emitters (like most low-power LEDs) are "potted" in transparent epoxy. As mentioned in other answers, a "near-IR" emitter typically emits a small amount of visible light; but The emitters used in some TV remotes have a dye in the epoxy (looks black or very deep blue) that absorbs all of the visible emission. Other TV remotes put the emitter behind a similarly colored window, and still others have an emitter in a "water clear" package that allows you to see a faint red glow when a button is pressed. \$\endgroup\$ Aug 2, 2017 at 17:14
    \$\begingroup\$ btw, a lot of video cameras (like the one used to make Paris Hilton's video) use filters on the LED emitter so they are less bright, and used for shorter ranges. They are labeled as being for night-vision. That camera omits the IR filter on the CCD. Most cameras can see some IR (unless they have internal filters) so they make great tools to "see" if your TV remote is working or not. \$\endgroup\$
    – SDsolar
    Aug 2, 2017 at 19:29
9
It isn't red light at all. It's infrared light which is perceived as red.
The human eye has three types of cones (color sensor cells): S-cones, M-cones, and L-cones. They're roughly equivalent to blue, green, and red color sensors. Here's an approximate set of response curves for the three types:
Human eye spectral response curve, from Wikipedia
L-cones are mostly sensitive to red light in the 560-580 nm range, but will respond weakly up to 1000 nm, which is well into the infrared range. If an infrared emitter is bright enough -- which the LEDs on an infrared camera certainly are! -- it will activate L-cones, making it appear red.
  • \$\begingroup\$ Those curves also illustrate why colour blind people with e.g. impaired L-cones (such as myself) have trouble distinguishing red tones, but can still see most of them with their M-cones. \$\endgroup\$ Jul 7, 2020 at 19:19
cheap cameras from china or sourced from a big box store will usually use 840nm-850nm leds driven very hard to produce the illumination (mostly invisible spotlight) for their night vision.
The LED energy output as Light covers something 20nm+ or minus the listed wavelength(center wavelength).
especially in the dark most human eyes(depending on genes)have at least a weak response to something like 900nm. Tests by professionals done as double blind (the test methodolgy not vision lol) have shown some people can reliably detect a little past 1000nm. This doesnt mean it lights the room up. It means when someone in another room switched the ir light on in the test room the person was able to perceive enough of change in their vision that they answered "was it on" correctly over 50% of the time.
your eyes response/signal of brightness to brain trails off like a bell curve with high and low wavelengths and no two people have exactly the same vision (as some spectral charts posted would suggest).
. there is another thing at play as well. Something like a double bounce of the photons inside the eye allows them to trigger a stronger than otherwise would have happened activation. I tried to google and find the paper i happened across last week but i had no luck. maybe someone else can chime in.
practically speaking/applied: the higher you go nm wise the less visible it is, especially at the point its coming from.
If you want ir night vision cams that doesnt scream "here is my camera" or cause a passer by to notice the red orb 10ft off the ground from a distance, look for 940nm ir led illuminators. In pure dark and close to it you may see it but it wont be the obviousness of the 8xx nm or 7xx nm emitters.
most cameras have less sensitivity at 9xxnm but the systems do exist and regular cameras with out ir filters will usually see this much better than your eye. there are some youtube videos comparing 840 and 9xx emitters with average cameras.
its important to note that although the IR light sources are perceived as only glowing faintly, a strong ir source can damage the eyes. So if you buy high powered IR iluminators do not put it next to your eye ball and look at it! You will fry your eyes!
I noticed one commented talked about the price, but its really not that bad and has been following its own moores law so if you looked 6 months ago its worth looking again. At the other end of the spectrum in UV land leds that were a lab experiment 6 years ago and cost 200 till a few weeks ago just dropped to $12 bucks. LED tech is moving fast. anyone quoting a price with out having looked at it that month should refrain from stating it as fact.
In this day and age, cameras can look like anything. Teddy bears, rocks, mud-wasp nests, whatever. But look at the thing. They swerved way out of their way to make it look as much like a camera as they possibly can. The red lights serve that same purpose, to make it look cooler and more intimidating.
I'm not saying they're not using IR LEDs that leak a little visible red. I'm saying they allowed or encouraged that.
Why? Some people who buy cameras want "garish". And those people write checks.
I personally think these ostentatious things make excellent decoys. Perfect world, the mud-wasp nest catches HD video of the crook smashing this thing.
  • \$\begingroup\$ That's why they sell actual decoy security cameras. \$\endgroup\$ Aug 3, 2017 at 16:36
Not specific to LEDs, but yes you can generate iR without visible light. Part of the problem with that is that filters designed purposefully to block out visible light can be pricey and require a high power source. The US military uses strobe marker lights that emit a strong visible strobe, but beneath a blackout shield so the light is only visible with night vision or other iR sensitive devices, and is 100% invisible to the naked eye. A strong LED could also have such a coating if needed. The LED itself could simply be bright white (or "clear").
  • \$\begingroup\$ Good information, but pertinent … ? \$\endgroup\$ Aug 3, 2017 at 16:35
    \$\begingroup\$ "Is that visible red light present as a convenience (introduced by grace of the component designer?) or as a by-product of emitting actual infrared light?" This shows that it is not an inherent byproduct of emitting actual infrared light. \$\endgroup\$ Aug 3, 2017 at 16:36
Re: 850nm vs. 940nm price points and by inference Moore's law.
As of July2020 one can now purchase 940nm IR fixtures for the same price as 850nm IR emitter fixtures on popular online marketing websites.
For example, one can purchase a "10W" IR floodlight in 850nm or 940nm for about US$28 (note: the "10W" almost certainly refers to the DC power requirements of the LED...and has little to do with the photon output of the LED as usually measured.)
If you're going to be using an IR illuminator to augment a surveillance system, then an 850nm illuminator is usually the better choice as common low-cost surveillance cams are considerably less sensitive at 940nm. Using the 850nm is also usually recommended for cameras that have an IR cutout.
Note that counterfeit items of all sorts (e.g. lithium cells) are a big problem on these websites so you should watch out for 850nm illuminators being labeled as 940nm.
Here are two informative links that should address this issue completely. The second one is the "double bounce of the photons" article (or at least similar to it) that someone discussed in an earlier comment.
I can see the 850nm LEDs with no problem, especially after I have let my eyes adjust by sitting in a dark room for 10 minutes (the longer the better) before I look at the "clear" IR emitter LED of a typical TV remote which does not have a filter in front of the LED. Many consumer devices place the visible light filter in front of the RECEIVER in the TV or other remote-controlled device which helps prevent swamping of the receiver with non-IR photons (KIND of like an RF band-pass filter that helps prevent swamping of the front-end of RF receivers by RF frequencies outside the intended range of received frequencies).
https://www.researchgate.net/post/what_is_the_difference_between_ir_illuminators_with_850_nm_and_940_nm_wavelength
https://source.wustl.edu/2014/12/the-human-eye-can-see-invisible-infrared-light/
I actually was looking at the infrared optic of a mouse, and every time I moved my finger over it, I would see a small amount (a very small amount) of red light. I read the paper included with the mouse, and it is not supposed to emit anything else but infrared. So from experimenting with that, I think humans can see infrared light to a certain point. The flashes of light were red, so I guess infrared really is red. It would make sense too, because it is called infraRED. Although the prefix infra means "below". It is a dark red that I see. Infra means below, so infraRED is "below red", so that must mean that it is a different color. I think infrared does dip into a tiny bit of the visible spectrum, explaining why I see red from the mouse optic.
