-2
I am currently attempting to mod a Nintendo 64 case to house my raspberry pi 3. I want to keep the original controller ports, but the port only has 3 pins. Would wiring a usb cable without the ground wire connected have any adverse affect?
  • \$\begingroup\$ Imagine a battery with only one terminal. How will you complete the circuit? Where will the electrons come from and where will the electrons flow to? \$\endgroup\$ – Harry Svensson Aug 3 '17 at 2:19
    \$\begingroup\$ Wiring two connectors with disregard to pin functions is not very smart to say the least. \$\endgroup\$ – Dmitry Grigoryev Aug 3 '17 at 9:21
Yes, there is a negative effect -- it won't work!
A ground is required as a reference for the USB VBUS line. Without a ground, current cannot flow through the device, so it will not work.
You need all four contacts (GND, VBUS, D+, and D+) to attach a USB device. You can't get away with fewer.
| improve this answer | |
  • \$\begingroup\$ VBUS isn't necessarily required. \$\endgroup\$ – Matt Young Aug 3 '17 at 2:22
    \$\begingroup\$ @MattYoung VBUS is required for a self-powered device to know it has been inserted. \$\endgroup\$ – Jeroen3 Aug 3 '17 at 5:18
