I have a microprocessor with two lines, /RESET and /HALT, which are independently pulled to +5V DC. To reset the processor, both of these lines must be grounded for at least 100 ms -- they may not be wired together and treated as one line. How do I create a circuit such that, when a single DPDT reset button (debounced) is pressed, both of these independent lines are grounded, and when it is released, they stay grounded for at least 100 ms?
  • \$\begingroup\$ How is this different from your previous question? electronics.stackexchange.com/questions/322127/… \$\endgroup\$
    – Jashaszun
    Aug 3, 2017 at 20:45
  • \$\begingroup\$ (1) And why do you need a delay? (2) Why are you using a double-throw button? (3) How are the inputs debounced if they halt the micro? \$\endgroup\$
    – Transistor
    Aug 3, 2017 at 20:52
This kind of problems are usually addressed by a specialty circuit called "voltage monitor", or "voltage supervisor". Check distributors for ICs like MIC803, APX809, MAX809, etc.
These are 3-pin devices, and no need for any de-bouncing.
Build a pair of these mosfet circuit for 2 of the pins, connect both mosfet gate together. Time delay depends on C1 and R3.
    \$\begingroup\$ The basic idea could work, but I think you want NMOS not PMOS. Also, the specific part you chose is really not suitable. A small signal MOSFET such as the BSS138 is more than adequate. Note that the OP said it is a 5V system, so you may want to change VCC to 5V. \$\endgroup\$
    – mkeith
    Aug 4, 2017 at 3:00
