I am routing a two-layer PCB with a 10MHz SPI bus. (See picture below.) The device on the left is the 5V master, the device on the right is the 3.3V slave, and the IC in the middle is a 74XX08 quad AND gate to perform level conversion on the MISO line.
The trace labeled SO is the slave's MISO which goes to pins 1 and 2 of the 74XX08. This is converted to 5V and output on the 74XX08's pin 3 which goes to the master on the trace labeled RX1.
The master's MOSI line goes directly to the slave on the trace labeled TX1 (bottom layer).
Finally, the master's SCK line goes directly to the slave on the trace labeled XCK1.
All of the other traces in the vicinity are extremely low speed.
My main concern is that the SCK, MOSI, and MISO lines cross over each other near the bottom right of the picture. Will this, or other aspects of the design be a problem at 10MHz?
RX1 length: 15.275mm
TX1 length: 17.834mm
XCK1 length: 23.700mm
SO length: 6.706mm
