My question is: If you have 20 12 volt SLA 95 Ah batteries and you need to hook them up to a 24 volt inverter what is the best way to wire these batteries?
Right now I have them grouped in groups of 2 to make 24 volts and those 10 groups are wired in parallel with all matching cables running to a buss bar for the positive and one for the negative.
The charge controller from the solar panels is hooked to those buss bars. Then I have 2 positive and 2 negative cables all matched in length wired to my 8,000 watt PSW Inverter. Does this sound right?
Thanks
