I am trying to synthesize my Verilog modules into 1 top module which contains all the modules extracted into 1 top module.
With setting -hierarchy option in write_file, I get all the modules separately. I am not really sure if I explained it properly as I am quite new to this.
  • \$\begingroup\$ Could you check your compile or compile_ultra command? There may be a switch that disables ungrouping. \$\endgroup\$ – ahmedus Aug 7 '17 at 14:24
  • \$\begingroup\$ Thank you for your answer, simply replacing compile with compile_ultra did the trick. \$\endgroup\$ – Damian Aug 8 '17 at 7:12
  • \$\begingroup\$ Many years since I used synopsys but if I recall correctly the command to remove the hierarchy was "ungroup -all -flatten". \$\endgroup\$ – Oldfart Dec 5 '17 at 19:59
The problem has been fixed by the compile_ultra command as mentioned in the comments. Here is some explanation.
If the compile command is used, ungrouping is disabled by default. So it should be enabled explicitly.
compile -ungroup_all
On the contrary, auto ungrouping is enabled by default if the compile_ultra command is used. No additional option is required in this case.
compile_ultra
