I'm designing a application circuit board which is having a power amplifier to amplify the RF signal.
Does the lines carrying the RF signal should have same impedance say 50 ohms?
Also does the signals passing through the capacitors and inductors of the matching circuit to the power amplifier should also have the same impedance?
\$\begingroup\$ What frequency? \$\endgroup\$– Andy akaAug 7, 2017 at 14:57
\$\begingroup\$ At 868MHz frequency \$\endgroup\$– AriAug 7, 2017 at 15:30
As a rule of thumb, you should use controlled impedance traces when the trace length is more than 1/10 (or maybe even 1/20) of the wavelength of the signal.
For 868 MHz, in FR-4 material, that means you would want controlled impedance when the trace length is longer than
$$l_{crit}=\frac{1}{10}\frac{c}{\sqrt{4.5}\ f} \approx 16 {\rm mm}.$$
You should minimize the lengths of stubs between the main signal trace and any filter components. Typically you can make the stub length 0 by simply putting one pad of the filter component directly on top of the trace.
You should also minimize parasitic capacitance and inductance associated with the pads where the filter components mount. At this frequency, though, if you're using 0603 or 0402 sized parts, you will likely not have too much difficulty. You might consider adding ground cut-outs below any pads where you have a strong need to minimize parasitic capacitance (for example the mounting pads for capacitors below 100 pF).
I understood that we no need to worry about controlled impedance when trace length is less than 1.6 cm in my RF PCB design.
Image explanation:
Here I am attaching the image of "output end of a power amplifier(PA)", which gives 1.5-j1.7Ohm impedance at output pads(12th & 10th) of the PA. And then it is being matched to 50 Ohm single ended impedance using matching circuitry.
Note: we have replaced strip-lines in the schematic with inductors.
