I have a CAN circuit from another project, and I want to reuse it and connect to my microcontroller, however it is a 5V transceiver and my microcontroller is 3.3 V, is it OK to connect TX and RX directly to my microcontroller?
Microcontroller: http://www.st.com/content/ccc/resource/technical/document/datasheet/03/b4/b2/36/4c/72/49/29/DM00071990.pdf/files/DM00071990.pdf/jcr:content/translations/en.DM00071990.pdf
Transceiver: http://ww1.microchip.com/downloads/en/DeviceDoc/20001667G.pdf
The pins I want to use are pin 93 and pin 163.
Microcontroller output:
Enter image description here
  • 4
    \$\begingroup\$ If and only if the mcu's pins are 5V-tolerant. Check from datasheet. \$\endgroup\$ – Rohat Kılıç Aug 7 '17 at 22:15
    \$\begingroup\$ @RohatKılıç I checked the I/O structure, they are 5v tolerate I/Os \$\endgroup\$ – yxing Aug 7 '17 at 22:44
    \$\begingroup\$ You also need to verify that the specified output high voltage of the MCU running on a 3.3v rail comfortably exceeds the input high threshold of the CAN. Often this is the case, but not always - you should actually compare the VOH of the MCU data sheet to the VIH of the CAN data sheet at the intended supply voltage for each. \$\endgroup\$ – Chris Stratton Aug 7 '17 at 23:03
    \$\begingroup\$ You need to compare the VIH and VOH specs. For example the VIH of your transceiver is listed at 2 volts, ie, it needs this voltage or higher to reliably interpret a "high". Probably the STM32 output will exceed that on a 3.3v supply, but it would be a good exercise to find the line in the data sheet that says so conclusively. \$\endgroup\$ – Chris Stratton Aug 7 '17 at 23:41
    \$\begingroup\$ @yxing I know that your goal is to re-use your circuit for the CAN transceiver that you listed above, but just FYI, the MCP2562 does the RX/TX level shifting for you. Check it out: ww1.microchip.com/downloads/en/DeviceDoc/20005167C.pdf Figure 1-2, page 6. \$\endgroup\$ – Daniel Aug 8 '17 at 23:59
It should indeed work
The Vih on the TXD pin of the CAN transceiver you're using is 2.0V, while the Voh for the STM32 is 2.4V; considering that the STM32 family has 5V tolerant input pins for most of its digital-only I/Os (including the ones you're using assuming we're talking about the LQFP176 package here), you're good on both sides of the deal here.
