enter image description hereI am new to this site.
I have a circuit and need to measure the current through a diode.
In my circuit i have a resistor and then a diode.
Do i connect the multi meter where i have in the picture? After the resistor, just before the diode to get measure the current through the diode?
Thanks.
    \$\begingroup\$ Please provide a circuit diagram! "In my circuit i have a resistor and then a diode." can mean anything. \$\endgroup\$
    – Curd
    Commented Aug 8, 2017 at 8:28
  • \$\begingroup\$ Hello, i'm sorry. I have attached a photo now. \$\endgroup\$ Commented Aug 8, 2017 at 8:34
  • \$\begingroup\$ Yes this will work: make sure the multi-meter is set to measure current. \$\endgroup\$ Commented Aug 8, 2017 at 8:34
    \$\begingroup\$ You can also measure voltage across the resistor, as long as there are no connections (paths to divert current) between in and the diode. \$\endgroup\$
    – user16324
    Commented Aug 8, 2017 at 12:35
you can place it anywhere before the diode , after the diode or before the resistor remember that current in a series circuit is equal anyware becouse there is only one path for the electrons to go
That's the way to measure the current flowing through the circuit, set your meter to the amps function, and 200mA or maybe 20mA.
The meter can be put into any of the wire connections and still read the same current. The same current flows through all components in the loop.
Note the meter will drop a small voltage, perhaps up to 200mV, which will reduce the current flowing slightly. You can estimate the current by measuring the voltage across the resistor (using the DMM on voltage), and using Ohm's Law. Obviously this depends on the accuracy of the resistor for the conversion to current, but it avoids the voltage drop of the meter on its current range. While the meter will take a little current, this method of connection will disturb the circuit far less than the current connection. It also means you don't have to break the circuit to estimate current.
One further, very important (for me) point is that your meter stays on the volts setting. If I put my meter on current, it tends to stay there until I next try to measure volts, and probably kill it. Always take your meter off current after using it to measure current!
  • \$\begingroup\$ Thank you for your reply and help. You said this is the way to measure current through the circuit. I need to measure current through the diode. So is that still correct? Thanks. \$\endgroup\$ Commented Aug 8, 2017 at 8:43
    \$\begingroup\$ Current stays the same in all parts of that simple circuit, however the voltage changes. Check out Kirchoff's Laws... \$\endgroup\$
    – Solar Mike
    Commented Aug 8, 2017 at 8:53
