-1
I want to build a circuit with multi AND logic which may trigger different LED by different combination of switch
Here is my thought:
So when I press 1,2,4 it will trigger one LED and 1,3,4 for another
But I don't know how to achieve this since it might trigger both LED with those combination
So how can I have different switch combination to trigger different LED but with same switches?
  • \$\begingroup\$ Press sw2 and sw5 means both lights on, 3 and 4 no function \$\endgroup\$ – Solar Mike Aug 8 '17 at 10:50
  • \$\begingroup\$ You press 1,2,4 ... Where is 1? \$\endgroup\$ – Bart Aug 8 '17 at 10:58
  • \$\begingroup\$ Oops sorry plus one to all the numbers to match the switch \$\endgroup\$ – Andrew Young Aug 8 '17 at 11:01
  • \$\begingroup\$ The polarity of your battery is reversed. If it is not a typo, when you apply the voltage to the LEDs you could fry them. Most common LEDs have a max reverse voltage of about 6V~8V. \$\endgroup\$ – Lorenzo Donati Aug 8 '17 at 11:36
    \$\begingroup\$ You should edit the question, not fix it in the comments. \$\endgroup\$ – Bart Aug 8 '17 at 11:50
This circuit should do it:
  • \$\begingroup\$ How about if I also want to achieve 1,2,3? \$\endgroup\$ – Andrew Young Aug 8 '17 at 11:02
    \$\begingroup\$ @AndrewYoung that is different question. Here I gave you answer to original question. It is unclear what you want to achieve. I would use microcontroller for more complex combinations. \$\endgroup\$ – Chupacabras Aug 8 '17 at 11:38
