I am driving a stepper motor using microstepping techniques. For the input signals to the driver, step and dir are used. More than 100,000 steps/second speed is target. The PWM frequency is below 100KHz. How to convert the step pulses into PWM pulses synchronously ? I want the rate should be same even though the constant buffer delay exists. At this moment, ISR routine for step pin handles counting up/down pulse.
But when i mill something for test on my CNC with my stepper drive, the 3D output quality isn't pretty good compared to with other vendors high performance closed loop stepper.
So i guess there is an input jitter on step pulses.
    \$\begingroup\$ "i guess there is an input jitter on step pulses", do you have anything to measure this with? \$\endgroup\$ – pipe Aug 8 '17 at 13:55
  • \$\begingroup\$ How are you generating the PWM, and what is it driving? \$\endgroup\$ – Bruce Abbott Aug 9 '17 at 20:44
  • \$\begingroup\$ I have checked input pulses applying into other vendors drive. It works correctly compared to my drive. My logic to change step pulses to PWM pulses isn't complete i think. I wonder if there is better algorithm \$\endgroup\$ – Paul Jay H.K Aug 10 '17 at 2:04
