I have completed my schematic design and started PCB layout. I am considering two layers and 45 mm x 95 mm. There are not any critical signals and according to current values of nets, I will draw power nets with 40 mils and 12 mils for others.
My desired board size is indicated at the bottom-left side of the image below. Do you think that this size is enough for these components? Thank you for sharing your ideas. I am trying to put it as at most 2 layers because of the cost of 4 layers is much higher than relative 2 layer board.
This is the layout;
